help in manchester area
andybnwc Aug 3, 2009
  1. andybnwc
    andybnwc Member
    752
    Im part way through doing a engine pull in my stolen recovered S4 before i go and rent a crane has anyone near manchester got one i could borrow and maybe even help with the heavy bits ?
  2. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    Hi andy i thought your S4 was when someone fell on it or have i mixed you up with someone else, whats wrong with your engine?
  3. andybnwc
    andybnwc Member
    752
    We had a break in and they stole the S4 and crashed it . the engine has broken of its mounts and moved back .I need to pull it complete with subframe to see whats actually broken.
  4. andybnwc
    andybnwc Member
    752
    Ok any tips on the propshaft bolts got 2 out but now need to turn it , i presume jacking 1 rear wheel will be enough to do this? would it help if i drop the subframe a little to get more space to work on them?
  5. Siena
    Siena Active Member
    2,626
    Andy, are you referring to the front half of the subframe, or rear?
  6. aragorn
    18,022
    718
    yer if you jack a wheel and pop the tranny into neutral you should be able to turn the prop.
    Not sure about lowering the subframe, i'm not too familiar with the underside of a quattro.
  7. Siena
    Siena Active Member
    2,626
    You don't need to lower the subframe, Andy.
  8. andybnwc
    andybnwc Member
    752
    ok no worries ill just give it a spin , one other thing where is the best to use axle stand when dropping the subframe?
  9. Broken Byzan
    13,237
    465
    If you remove the alloy shield from below the rear flange of the gearbox, its only 2 trorx screws, the prop ones are then accessable with it in place.
    You will probably find the gearbox mounts sheared too, the pull i just did had intact engine mounts, but smashed gearbox ones, also the impact had pushed the timing belt cover into the belt shreading it and causing the belt to jump damaging velves
  10. andybnwc
    andybnwc Member
    752
    engine runs fine fortunatly but wont drive when in gear , i can get to the prop bolts just not much room to use a socket , i think it will help if i remove the twin pipes , think thats gonna be my next step
