Help - Immobilizer light still flashing
harps21k Dec 21, 2009
  1. harps21k
    harps21k Member
    109
    Hi Guys,
    I am on the verge off shooting myself, as my car is just pi**ing me off.
    A month ago my Immobilizer light started flashing and the car would start and cut out straight away. Tried 2s ets of keys and the same problem. Both key just cant stop working at the same time so I called the AA and the guy spent at least 1 hour trying to find out what was causing the issue. He ran a signal test on his laptop with the key in the ignition and it was not reporting any signal being read on the key. He said that the common fault on A3's is the reader coil on the ignition.
    So I went along to Audi and got a new ignition barrel made from my existing keys, so I would not have to reprogramme them.
    Today I fitted the new barrel and recharged the battery as it went flat and guess what it still flashing.
    I freeze my nuts off on the bus to get to work and need my A3 back up and running. Can anyone help?
  2. sportquattro
    sportquattro Active Member
    845
    51
    Take it to Audi (or a good VAG specialist), get them to sort it - the danger is you'll end up changing umpteen things that don't work and this time of year is too cold to be messing around with a dead car in the driveway freezing ones nuts off.
  3. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Yeah Audi will kindly change everything for you and charge you £100/hour for the privilege and still won't guarantee a solution as they are dire at fault finding, especially older cars. It was probably them that told you you needed a new reader coil, when it's almost never the reader coil. they're very good at replacing parts, terrible at problem solving.
    Chances are it's the wiring. Seem to remember the wiring connections for the reader coil can either get coroded making a bad connection or also just picks up interference from the other wires in the loom, especially on older models. Firstly try moving the steering column up and down and see if it starts. If it does then you need to pull apart the wires in the loom running from the keyswitch, so they're not all bunched together. If you still get the problem then wiggle the wires around to see if it's a bad connection. Has to be one of the two.
  4. shark_90
    shark_90 Member
    96
    It's probably the wiring between the reader coil and the cluster, or could even be the cluster causing the problem (rare, but have seen it).
  5. Nilz
    Nilz Defo worth the wait :) Team Ibis TFSI Owners Group quattro Audi A4 saloon S-line owners group Manual
    11,367
    908
    Where are you based mate, could recommend a few places if that helps.
  6. vince, A3 turbo
    vince, A3 turbo Member
    89
    harps.mine does the same thing..its a pain in the ass,,mine does it because i dont have the original key i think,,,but if u keep turning the ignition on and off the light wil turn of so u can still drive,,some times it will be fine but some times it takes 4 or 5 attempts,,better then getting on the bus lol
  7. woody.dub
    woody.dub Member
    98
    I can sort this for you mate, where abouts are you
  8. vince, A3 turbo
    89
    how haha i would love to no lol,
  9. s3wil
    s3wil New Member
    17
    I can sort this for you, pm me
  10. leshkin
    leshkin Hold my beer... VCDS Map User Gold Supporter Team Sepang Audi S3
    2,713
    1,610
    The reader coil is the thing that generally dies and is an extremely common fault. Scanning the car with VCDS should help you to identify if the engine is not starting as a result of an immobilizer or something else.
    The error yo uare looking for is '01176' or '17978'
    Good troubleshooting guide for this issue - VW immobilizer information and troubleshooting
    How-to replace the part - audipages Immobilizer Wiring Replacement
  11. MRGOOSE
    MRGOOSE New Member
    Hi there i am having the same problem just yesterday i drove down and up from wales with no problem and today when i try start it it starts up for a second and dies out the key light keeps flashing. Can anyone help please?????
  12. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,983
    2,741
    The information to help you is linked above. As stated the coil that reads the keys is a known issue. Have you tried a different key, the actual sender part in the key is made of glass and can be damaged if the keys are dropped a good distance.
  13. Scott Stevens
    Scott Stevens New Member
    Anyone help me??? My bloody imboliser is flashing! I have tryed turning the key load off times and no luck! Car is stuck on pals drive It's a 1.8 R reg!! It happened before but I turned the key load time and it worked! Been sound
  14. Scott Stevens
    Mine won't do that now it has before but refusing now ...
  15. Ruhel
    Ruhel Never seen a fuel needle go down so fast! TFSI Owners Group VCDS Map User Team Phantom Audi A3 s tronic S-line owners group
    241
    101
    43
    Do you know anyone local that can scan the car with VCDS. Should throw up an error code so you know where to start problem solving.
  16. Erikn89nl
    Erikn89nl Well-Known Member
    847
    343
    Check the electrical connection to the reader coil on the ignition barrel
