Help!! Headlight doesnt go off
azzi79 Mar 23, 2011
  1. azzi79
    azzi79 New Member
    hi all, i need help.
    i just installed a turbo boost gauge meter on my 2009 8p 2.0T A3 today. its a new south performance gauge. everything works well... except my lights does not turn off at 'off' position :crying:. the light work normally at low beam (LED) and normal beam and also the fog lights. the only problem is at off position the light doesnt turn off stays in normal beam mode.
    i need your advice. thanks
  2. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    Try and take the battery out for a couple of min.
  3. azzi79
    azzi79 New Member
    alright will try that. thank you. will let you know if it works.
  4. Khufu
    Khufu Well-Known Member
    5,704
    31
    I'd also check the fuses. If your light switch is disconnected and you start the car the lights come on.
  5. azzi79
    azzi79 New Member
    i went to the shop today. he took the battery out and check the fuse, the problem still there. the guy told me that i might be the light switch. could it be possible??
  6. NHN
    29,298
    1,701
    Yeap good call Ewan, check your light switch if its come loose, as its 09 then maybe under warranty still.
  7. azzi79
    azzi79 New Member
    will go down to the dealer soon. thanks for the help guys. will update on anything.
  8. azzi79
    azzi79 New Member
    i have just notice that my hazard light switch illuminates even when the car is locked.
  9. NHN
    29,298
    1,701
    Yeah will do, goes of after a while.
