*Help* Hazard Warning lights
hass Nov 15, 2006
  1. hass
    hass Member
    72
    I'm facing this problem since yesterday, my car was parked at home, when I came back the hazard lights were ON. I tried to turn it OFF from the bottom. But after few minuets they become ON again.
    I tried to disconnect and connect the battery but they lights comes ON. for time been i removed the hazard fuse.
    Do you think its from the hazard relay ?????
    help plzzz
  2. VAGMAN1
    VAGMAN1 Member
    306
    mine had this problem when I first bought it, and I hate to tell you this but............it was the airbag control unit which was kaput. apparently it's the car's way of telling you that there is a major airbag fault. however, the airbag light was not illuminated BUT it did blink on when you turned on the ignition, then went out. only way to know for sure is a diagnostic.
  3. spuddie007
    spuddie007 Thomas the Tank Engine - Choo, Choo!
    222
  4. hass
    hass Member
    72
    how much did it cost you ???? and did u fixed or not ???
