HELP!!!! HALDEX 4WD PROBLEMS
S3 ROCKS Sep 3, 2007
  1. S3 ROCKS
    S3 ROCKS steve
    228
    HI EVERYONE
    IM IN NEED OF SOME ADVICE. I RECENTLY BOUGHT A 210 BHP S3 Y REG THAT HAS HAD A STAGE 2 REMAP. I NOTICED RECENTLY THAT IM GETTING WHEEL SPIN FROM THE FRONT WHEELS IN THE WET, REGARDLESS IF I FLOOR IT OR EASE THE POWER ON.
    TO MY KNOWLEDGE THE HALDEX SYSTEM SHOULD TRANSFER THE POWER EVENLY TO ALL 4 WHEELS DEPENDING ON YOUR DRIVER INPUT, SO YOU SHOULD NEVER GET WHEELSPIN. I TOOK IT TO AN AUDI DEALER WHILST IN GERMANY AS THE CAR WAS BEEPING 4 TIMES ON START UP, AFTER READING THE MANUAL THERE IS NOTHING THAT EXPLAINS WHAT THIS IS. ALTHOUGH FOR THREE BEEPS IT IS A MAJOR FAULT THAT WILL THEN RELAY THE INFO ON THE DRIVER ON BOARD DISPLAY. THE AUDI DEALER HOOKED IT UP TO THE DIAGNOSTIC MACHINE AND IT CAME UP WITH A FAULT IN THE HALDEX SYSTEM THAT WAS STEUREN OR SOMETHING IT TRANSLATED TO ELECTRICAL SYSTEM FOR THE HALDEX. HAS ANYONE ELSE COME ACROSS THIS PROBLEM. I REALLY DONT WANT TO BE RIPPED OFF BY THE DEALERS AND SO WANT TO GO IN THERE ARMED AND AWARE OF WHAT THE PROBLEM IS AND HOW MUCH IT SHOULD ROUGHLY COST. CHEERS GUYS AND GIRLS
  2. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,250
    2,073
    THE BEEPS ARE THE ALARMS BACKUP BATTERY LOSING POWER.
    (why am I shouting?)
  3. foolish3uk
    foolish3uk Member
    455
    most probably a haldex ecu electrical fault, probably going to require haldex ecu which costs about £400.00 plus fitting approx £150 at a dealer.
    really need to see the print out first though!
  4. claudefrog
    claudefrog Member
    372
    probably the Haldex unit, you should be able to pick up a second hand one much cheaper than the above price.
    failing that buy the uprated haldex controller.
    PS NO NEED FOR THE CAPS LOCK
  5. S3 GAZ
    S3 GAZ Member
    381
    17
    my mate. (alan_s3) on here had the very same problems you have described. same fault was found. i got him a second hand haldex unit from a golf mk4 r32 off ebay for £42. total bargain. cost him £30 to get it fitted
    audi quoted £550 fitted
  6. foolish3uk
    foolish3uk Member
    455
    what a guess:rockwoot:
  7. S3 ROCKS
    S3 ROCKS steve
    228
    Thanks for all the replys, guess i better get searching for a second hand haldex unit
