HELP GETTING SLIGHT WOBBLE THROUGH STEERING AND FEELS LIKE THROUGHT THE FLOOR PAN..
damenw Apr 26, 2013
  1. damenw
    damenw New Member
    13
    hi guys just joined this forum to see if i can find out what maybe the cause and fix to a ever so slight vehicle shake through the steering wheel and also feels like its going through the vehicle as you can feel it on the passenger side. under acceleration does get worse but after 40 mph it stops ???? have new tyres all round and balanced. can anybody advise...
  2. pluves1
    pluves1 Active Member
    725
    133
    43
    Do you have Quattro?
  3. damenw
    damenw New Member
    13
    no its an Sline a3 1.9 tdi DSG
  4. rsbowling
    rsbowling Member
    46
    It maybe that a newly fitted weight has fell off the wheel, being a nearside wheel its subject to manhole covers and potholes more. Id check that first, hopefully its something as simple as that.
  5. damenw
    damenw New Member
    13
    maybe could be issue. not checked weights. there should be 2 sets on the wheels top and bottom opposite to each other . is that correct. if its not this what other reason could cause this problem...
  6. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,763
    354
    2 of the same thread?
    Anyway, it's not a case of "should have 2 here and 2 here", each wheel needs to be balanced individually. Only way to check the right weights are on is to get them rebalanced.
  7. damenw
    damenw New Member
    13
    okay thanks will look into the balancing see if that solves the problem
  8. RPB
    RPB Active Member Team Ibis Audi S3 Black Edition DSG
    399
    70
    I'd still be thinking wheel balancing too. To be honest there are some really good tyre fitters out there now and with the new equipment I have not had a case of this for a lot of years.
  9. blackshuck
    blackshuck Member
    440
    It's most likely the balancing as others have said! However if you have front spacers fitted and there not hub centric this will also cause similar issues,
  10. Double J
    Double J Member
    93
    15
    I get this with Quattro...what's the difference?
  11. blackshuck
    blackshuck Member
    440
    I don't get any wheel wobble with Quattro
  12. Double J
    Double J Member
    93
    15
    No I mean why specifically mention Quattro, is there a common fault?
    Mine was fine until I horribly bottomed out one time...
  13. TDI140
    TDI140 Well-Known Member
    1,626
    174
    Could be wheel balancing, tracking, or i had this with budget tyres as they came on the wheels when i got them but i switched a week later and the vibrating had gone
  14. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    66
    Could also be buckled wheels.
