Help, gearbox stuck in two gears which codes please?
Dj0gt0 Dec 19, 2012
  1. Dj0gt0
    Dj0gt0 New Member
    sady this afternoon my 2001 A3 Quattro decided she no longer wants to reverse, engine stalls under clutch yet no movement
    informed by AA dude its stuck in two gears, got in back to the local garage which ive used for a while
    asked the guy what the best solution is, he said get a re con box, but im lost with the engine codes
    ARY EVK EFY
    do i just need a gearbox for engine type ARY or does the box need to also match EFY ?
    found quotes for £400 who guarantee its correct fit, yet another for £320 but not 100% sure if it will fit
    many thanks in advance
    (i have tried an afternoon of google before posting)
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,792
    10,897
    ​Your engine code should be on your v5 document. :) x
  3. Lewis583
    956
    91
    If you look under the boot carpet or inside your service book, you will see a sticker similar to the image below.
    On the image below I have circled where the engine code and gearbox codes are listed.
    Use the ones from YOUR sticker when sourcing a gearbox.
