Help from Milltek Owners please
RobinA3 Jun 12, 2009
  1. RobinA3
    RobinA3 Well-Known Member
    1,827
    46
    Need some help with the milltek system on the Quattro, ideally a cat back system.
    The mid section which joins the back box to the standard cat section i need to know what type of joint it is, does the mid section slide onto the cat section and is clamped or does milltek supply a seperate joint clamp thing with the exhaust system?
  2. boggym
    boggym Member
    158
    It's just a slip joint with a standard clamp that bolts up. There's actually quite a bit of adjustment so fitting is fairly easy.
