Help from an expert please? maybe NHN Error code inside <3
mkimjoon Nov 17, 2010
  1. mkimjoon
    mkimjoon Member
    166
    27
    So unlike you guys here in the US, we don't get S3.... i wanted a ibis white and no dealers in my area had it in S-line so i bought it in Premium. After 2 years of owning the car i have bought a used S-line seats. First time i have swap the whole seat and i got an air bag light. So after a few months i decided to just swap the cushions and the cover out since the frames are the same. I wanted to use my original frame with original connectors. However, this hasn't fixed my problem. I checked to see if any wires are lose but found nothing... Here is the error code i'm getting, i've been driving it since then
    Saturday,17,April,2010,20:22:36:20331
    VCDS Version: Release 908.2
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Control Module Part Number: 8P0 959 655 A HW: 8P0 959 655 A
    Component and/or Version: Airbag 9.41 H13 4290
    Software Coding: 0032605
    Work Shop Code: WSC 06314 000 00000
    Additional Info: 8P0910339 BF-Gewichtsens. 001 0020
    Additional Info: Geraet 00000
    2 Faults Found:
    00591 - Seat Belt Switch; Driver (E24)
    007 - Short to Ground - MIL ON
    Freeze Frame:
    Fault Status: 11100111
    Fault Priority: 2
    Fault Frequency: 56
    Reset counter: 247
    Mileage: 61197 km
    Time Indication: 0
    Date: 2010.04.10
    Time: 16:43:55
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 2
    Fault Frequency: 52
    Reset counter: 31
    Mileage: 61197 km
    Time Indication: 0
    Date: 2010.04.10
    Time: 16:53:10
    PICS b/c u clicked thanks!
    Car is lowered now, i had to raise it up due to the fitment of the OZ futuras as i just got them. 18x8.5 ET45 front 18x9.5 ET 45 rear (Flushed to the fender)
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    you may have nipped a wire going from the bit the seatbelt clicks into mate
  3. NHN
    29,351
    1,720
    Assuming you've tried to clear them 1st, but I'd say maybe these new seats didnt have the seat belt warning fitted????
    Easy way to check is if the seat belt buckle has any wiring going to them, if not thats the reason.
    I'd check all positions on the car loom side of connectors in the floor have a corresponding pin on the new seat connectors.
    As for expert, wouldnt go that far as many can help including Phil.
  4. sub39h
    sub39h Active Member
    2,502
    little harsh nige! i'd say phil was an expert :p...
  5. NHN
    29,351
    1,720
    Whats harsh about that comment.
  6. sub39h
    2,502
    your implication that phil isn't an expert? nm lol
  7. NHN
    29,351
    1,720
    NO numnuts, I was referring to myself, read the thread title.
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    haha like nige im hardly an expert (i got what you meant nige ;)) learning every day and once you start breaking things down they get less and less complicated, my dad i would call an expert not me though, cheers for the thoughts subby, as for the op id be taking niges advice first however as from the way i read your post youve kept the existing airbags buckles etc?, in which case its a fault clear and if not a nipped wire at a geuss
