Help fitting Bose
tommo5600 Apr 22, 2013
  1. tommo5600
    tommo5600 Member
    42
    I have the Bose speakers, sub, and amp on the way but where the hell does the amp and sub live?!?!?!
    I'm guessing the sub is under the rear seat?
    I plan on making a how to for doing this and also the rear door cards so any hits would be great.
    2004 3 door v6
  2. fangio
    fangio Well-Known Member
    1,472
    174
    Sub/amp is behind n/s boot panel!
    tommo5600 likes this.
  3. tommo5600
    tommo5600 Member
    42
    Thanks buddy!
  4. AndyMac
    9,832
    45
    Good Luck with that!
    The sub goes behind the nearside boot panel, where the current sub is. The amp goes on the opposite side.
    I do hope you have the full wiring loom otherwise it is an almost impossible task. Even with the full loom it's a major job for a small improvement - that's why there are so many sets on ebay!
    You need to rewire all the speakers, run power front to back as well as the front & rear pre-outs from the HU to the amp, then additional wiring from the amp to the sub. All of the looms use bespoke connectors.
    This stealth sub install guide will give you some idea:
    http://freepdfhosting.com/8677a0ca0d.pdf
  5. tommo5600
    tommo5600 Member
    42
    ****! lol ah well i'm doing it anyway. thanks Andy
  6. fangio
    1,472
    174
    Bejasus! Never seen so much work for so little gain............:wtf:
  7. tommo5600
    tommo5600 Member
    42
    never mind, if anything it makes me want to do it more. plus can't fit the speaker covers and not have the rest!
  8. _G_
    _G_ Active Member
    876
    It's not worth it. Uprated sub in the back will make a mahoosive difference. Search the site for ideas. Bose is overly rich sound with tinny highs but if that's how you like your music then good luck with the install.
