help fitting a aux please
adam_may Jun 22, 2014
  1. adam_may
    adam_may Active Member
    150
    32
    Hi could someone tell me what I need to fit a aux to this headunit? Thanks Adam
  2. fangio
    fangio Well-Known Member
    1,482
    175
    I think you need to fit it via the CD changer plug, something like a Dension.
  3. adam_may
    150
    32
  4. fangio
    1,482
    175
  5. adam_may
    150
    32
    This is getting confusing lol so the connect2 quad lock is what I'll need?
  6. atownsend91
    atownsend91 Member
    80
    I've just fitted a connect2 interface adapter to my A3... very easy to do with some basic know how...
    As your head unit is the Double DIN unit... it may be different...
    Does your car have a cd changer ?
  7. adam_may
    150
    32
    This is in my friends car i don't think there is a cd changer fitted no. I'm guessing there will be a port on the back of the headunit to fit on though?
  8. atownsend91
    atownsend91 Member
    80
    Yup, I wired it into my empty cd changer slot... was super simple and you get a diagram to explain...
    just make sure it is properly grounded otherwise it will not work... I had to tap into the ground wire of the head unit for it to work.
  9. adam_may
    150
    32
    Is yours the single din CD player? As is looks on that link that fangio posted that they connect differently to the double din ones
  10. fangio
    1,482
    175
    That's a double-din, the buttons are underneath. It will have a quadlock plug into which the white plug on your ebay link should fit. It will only fit into the correct hole in the quadlock as the plugs all have different keyways and will only fit 'their' holes the right way up!
  11. atownsend91
    atownsend91 Member
    80
    Yes mine was a single din system... with the CD slot... basics lol
    I was so tempted to replace my head unit but then I'd miss the OEM look too much...
    with this connects2 box, it really helps when you cant afford the expense of buying millions of blank cd's
    I use Spotify on either tablets/ phones therefore an aux port was what was needed, managed to feed the wire down and out by the pedals and is now stray in the car so even people in the back seat can plug their music in... :)
  12. adam_may
    150
    32
    Right so the eBay link I posted will work with the double din? Fair bit cheaper than the connect2 ones!
  13. atownsend91
    atownsend91 Member
    80
    Hmm the one you posted literally just looks to be a simple plug solution... without the box... although it looks possible... i always thought it would still need to be grounded... as the connects box "bridges" a connection from the standard head unit plugs which plug into the back of it...
    Kind of hard to explain without being able to show you lol
  14. adam_may
    150
    32
    Yeah I have fitted ones in fords that are the same as the 1 in my eBay link but the actually have a aux button on the headunit
  15. atownsend91
    atownsend91 Member
    80
    Oh i see... well yeah the connects2 box is basically classed as an emulator... so it will pretend to be a CD changer and your head unit will then suddenly have a cd changer functionality...
    so with me... i had to double tap CD button to bring up cd changer to which before said "CD Changer Error" or something like that...
    now its plugged in, it shows CD changer - cd 1 track 1
    and the audio is then routed through the aux cable...
    does that make sense ?
  16. adam_may
    150
    32
    Yeah that makes sense. I have the sat nav unit in my S3 and that has an iPod dock connected to it and I use the cd changer function to play through the iPod Dock. Think it's going to be easier if I take that CD player out and take a picture of the back of it lol
  17. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,663
    117
    From your photo, you have a Symphony II+, which means that you have dedicated ports for the AUX-In. If you had a Symphony II (2003-2007), you could only install the AUX by using the CD Changer as an emulator.
    Because you have the Symphony II+, retrofitting AUX is a pretty easy task.
    This is the pin-out diagram of your stereo:
    The main question is if you want to do it as OEM, or aftermarket...
    If you want aftermarket (£11.20) you would simply need something like this:
    Audi A3 (Incl. S3) 03-13 Quadlock AUX In to RCA Adpator Lead Celsus | eBay
    (I can't seem to find one with a simple 3.5mm jack, possibly gap in the market there!)
    If you want to go OEM (~£30) then you'll need to follow the following: rnseauxin - Audi Retrofit
    (Ignore that it says for RNS-E, it also works on the Symphony II+ and you also don't need to buy 1J0 972 977 G)
    After either one is fitted, you'll then need to code in the AUX with VCDS.
  18. adam_may
    150
    32
    Right that clears it up thanks for that. Is it a pretty simple task to enable the aux with vcds?
  19. whinfs
    whinfs Member
    58
    its not a symphony II+ its a concert II+
  20. jb0o
    2,663
    117
    Good spot! Still supports AUX the same as Symphony II+.
  21. whinfs
    whinfs Member
    58
    cool I was hoping you'd say that - i'm wanting to add aux to my concert II+ too. i'll continue watching the thread :icon_thumright:
  22. adam_may
    150
    32
  23. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,725
    650
  24. adam_may
    150
    32
    I mailed the guy on eBay n he confirmed that it is the right one, going to order it so I'll let you know how it goes.
    When i unplug the CD player to fit the aux will the CD player ask me for a code?
  25. jb0o
    2,663
    117
    Connects2 is completely unnecessary mate, you're wasting money buying that. This interface should be used for stereo's without the AUX input, however your stereo does have the AUX input (which I said in my previous post) so you don't need this.
    It would work, but it works by emulating the CD Changer, which you don't need to do.
    This is perfect. Straight plug into the back of the Quadlock, code in and you're good to go. Good find mate.
  26. adam_may
    150
    32
    Would it save having to have the aux coded in if I got the connect2 one?
  27. B5NUT
    3,725
    650
    The connect2 would need to be coded for CD-Changer, so it makes no difference..
  28. jb0o
    2,663
    117
    Correct ^
  29. adam_may
    150
    32
    Thanks for that help. Does anyone know how to code the aux? Is it pretty simple?
  30. B5NUT
    3,725
    650
  31. adam_may
    150
    32
    Yes I know someone with VCDS but he has never coded a aux in before so some instructions on how to do it would be much appreciated lol
  32. jb0o
    2,663
    117
    Module 56-Radio
    adam_may likes this.
  33. adam_may
    150
    32
    brilliant thanks a lot for that. Just waiting for the cable to be delivered I will let u know how I get on
  34. adam_may
    150
    32
    Coded in and all working fine. Thanks for your help!
  35. emznjav
    emznjav Member
    76
    I have the old symphony with the built in 6cd changer and tape player what do I need to add the aux functionality?
  36. rory21388
    rory21388 Member
    53
