Help! Esp and brake lights on after DIS and cruise fit
Discussion in 'A4/A4 cabriolet/S4 forum(B6 chassis)' started by rob irl tdi, Sep 12, 2010.
  1. rob irl tdi
    rob irl tdi Member
    Jul 14, 2010
    240
    I fitted cruise today and Dis and I cannot get these lights off
    Cruise is working and I know DIS is working because I can scroll through them quickly before the warning lights come on
    What am I doing wrong that I cannot get rid of these lights?
    In measuring blocks the steering angle won't change from -2.5 when I turn the wheel
  2. Advert Guest Advertisement
  3. rob irl tdi
    rob irl tdi Member
    Jul 14, 2010
    240
    Sunday,12,September,2010,17:23:28:20000
    VCDS Version: Release 10.6.0
    Data version: 20100630
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E34A301196 Mileage: 159530km/99127miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 LJ
    Component: 1,9l R4 EDC G000SG 5934
    Coding: 00002
    Shop #: WSC 63351
    VCID: 6AD008B33C17
    WAUZZZ8E34A301196 AUZ6Z0D0163844
    1 Fault Found:
    18097 - Powertrain Data Bus: Implausible Message from Elect. Load Controller
    P1689 - 35-00 - -
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 4529
    Coding: 00000
    Shop #: WSC 00000
    VCID: E5CAFB8F5509
    2 Faults Found:
    01044 - Control Module Incorrectly Coded
    35-00 - -
    00778 - Steering Angle Sensor (G85)
    66-10 - Not Matched - Intermittent
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AA
    Component: A4 Klimaautomat 1324
    Coding: 00000
    Shop #: WSC 63351
    VCID: 60C46A9BCA2B
    1 Fault Found:
    00975 - Heated Rear Window (Z1)
    31-10 - Open or Short to Ground - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 C
    Component: int. Lastmodul RDW 0606
    Coding: 00001
    Shop #: WSC 63351
    VCID: 3260D0D3D447
    1 Fault Found:
    01326 - Control Module for Multi-Function Steering Wheel (J453)
    49-10 - No Communications - Intermittent
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 J
    Component: Airbag 8.4EP 1002
    Coding: 0010602
    Shop #: WSC 63351 000 00000
    VCID: 3E78F4E3101F
    No fault code found.
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 R
    Component: Lenksáulenmodul 1002
    Coding: 01041
    Shop #: WSC 00000
    VCID: 4280801364E7
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 M
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 00431
    Shop #: WSC 00468
    VCID: 336ED5D72B5D
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0704
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBDE8DB7B3ED
    Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
    Part No: 8E0 959 433 BD
    Component: Komfortgerát TBF 1612
    Coding: 07915
    Shop #: WSC 63351
    VCID: 74EC16CB6ED3
    Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 0204
    Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 0204
    3 Faults Found:
    01366 - Opened Due to Crash Signal
    35-00 - -
    00955 - Key 1
    35-10 - - - Intermittent
    01560 - Passenger Door
    59-10 - Can't Unlock - Intermittent
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186 D
    Component: concert II GRO 0004
    Coding: 01001
    Shop #: WSC 63351
    VCID: 285432BBE29B
    End ---------------------------------------------------------------------
  4. swarcup
    swarcup Well-Known Member
    Sep 9, 2009
    1,326
    40
  5. rob irl tdi
    rob irl tdi Member
    Jul 14, 2010
    240
    I've been looking at that guide when doing it. Just don't understand why the steering angle sensor value isn't changing from -2.5
    Am I entering the wrong code in for the brakes?
    Like do I enter the 15" part of the code for my brakes? its a 1.9 sport
    0x?xx in brakes what goes where the question mark is?
  6. rob irl tdi
    rob irl tdi Member
    Jul 14, 2010
    240
    Anybody?? Its wrecking my head
  7. chrisash32
    chrisash32 Member
    Nov 10, 2009
    573
    Hi,
    As the above sort of states in your print out, the ABS module has not been coded (Coding: 00000).
    This means you are not putting the correct code in and therefore the module is rejecting it.
    Once you have the correct code, it will work just fine.
    Have a look at what the code was in one of your previous scans before you did the cruise fit.
    Once that is done, all your probs should be fixed :)
    Chris
  8. Ryanmt
    Ryanmt Member
    May 30, 2010
    103
    Mine was the same, toook it apart and checked everything over and then rebuilt it. Still acting up but after a few times of recalibrating the steering angle sensor it worked. Was pretty weird
  9. rob irl tdi
    rob irl tdi Member
    Jul 14, 2010
    240
    Yea cheers lads. I got it all working. I just grounded the wire for pin 1 to an earth point behind the clocks for the washer sensor for the min.
    I fitted my armrest I got from Stoke Audi
    Next up is trying to do these footwell lights and puddles lights
  10. Garfie
    Garfie Member
    Jul 16, 2009
    179
    Glad you got it sorted in the end. I had similar mad panic moments when mine wouldnt accept the coding!!
    I also fitted the washer fluid low level warning sensor to mine. Bought the sensor, grommet, connector and repair wires for it and made the loom up. Fairly easy job actually if you decide to go for it.
  11. jimmy77
    jimmy77 Member
    Aug 4, 2010
    102
    really sorry for the possible stupid question but..... what does DIS stand for? i am looking at fitting cruise to my b6 190t quattro sport,what parts do i need? thanks
  12. DAylward
    DAylward Member
    Sep 14, 2010
    66
    I hope its not the same isue i had with my RS6 before i bought it as it cost £1600 to fix (under warranty) turned out to be the ABS control unit
  13. rob irl tdi
    rob irl tdi Member
    Jul 14, 2010
    240
    DIS is driver information system. Your should have it if you have buttons on your right wiper stalk. It controlls the computer in the middle giving you m.p.g, average speed.
    The sport just has miles till empty function enabled on the computer between the clocks. You cant scroll through anything
    I fitted a new stalk because the A4 sport doesn't get DIS as standard. SE spec does if I'm correct?
  14. rob irl tdi
    rob irl tdi Member
    Jul 14, 2010
    240
    I have all that to go in. Just need some good weather to run the wire down. They are sitting in a plastic bag for the time being.
  15. Garfie
    Garfie Member
    Jul 16, 2009
    179
    Just note that you will need to take the lower half of the washer fluid bottle out through the passenger front wheel arch, once the liner has been removed. Then you will be able to see the blank where the sensor goes in. There was a rubber seal already on the bottle but as the helpful parts man at Audi ordered me a new one I swapped it for that.
    The wire can pass into the cabin through a grommet at the base of the A pillar and it then comes out in the passenger footwell. I had the glovebox out to make routing it through to the dash easier.
