Help! ESP & ABS light just came on :( :( :(
Grangey. Jan 12, 2012
  1. Grangey.
    Grangey. Member
    226
    Yep, just like that out of the blue, both the ESP and ABS Light came on. I restarted the car for it to clear, only to come on 30 seconds later. ESP button is unresponsive when its on.
    Any ideas? :(
    God I hope its not expensive :(
  2. Mike B
    Mike B Well-Known Member
    1,101
    40
    Brake light switch?
  3. Grangey.
    Grangey. Member
    226
    ...Are you able to elaborate?
  4. hades-
    9,481
    646
    when the brake light switch packs in it puts abs esp light on
    your better off scanning it for fault codes
  5. quattrojames
    14,050
    577
    A fault in the brake light circuit can cause this, be it a bulb out or a faulty pedal switch (most common).
    If the brake lights are working fine then it might an abs sensor or something, best bet is to try and get a scan done.
  6. Grangey.
    Grangey. Member
    226
    How much do audi charge for scans?
    How much is a brake light switch and is it something im likely to be able to do myself?
  7. hades-
    9,481
    646
    very easy to do
    10 min job but why replace unless you know its at fault
    try your brake lights 1st
  8. Grangey.
    Grangey. Member
    226
    any ideas on cost of the switch?
  9. hades-
    9,481
    646
    cant rember what i paid was defo under 20 quid tho
  10. hades-
    9,481
    646
    audi charge to much for a scan where u from
  11. Grangey.
    Grangey. Member
    226
    Im in Oxford- so it deffo wont be cheap.
    For the sake of under £20 il give the switch a shot lol.
    Any guides or how tos on it? No idea where to find it!
  12. quattrojames
    14,050
    577
    Its on the brake pedal mechanism.
    If you PM me your email I'll send you a pdf guide, it's pretty simple.
  13. Pabs
    Pabs Active Member
    650
    54
    Audi charge an hours labour rate for a scan which is over £100 (think its actually £135) which is ridiculous, see if someone on here local has vag com, its definately a worthwhile tool to have
  14. Grangey.
    Grangey. Member
    226
    Yep, it does appear to be the break switch.
    Drove for as long as possible to work without using my brakes at all and the lights remained off for a good 5 minutes, a second after I used the brakes they both shot on.
    So il get one of them ordered and hope that sorts it :)
    I assume my brake lights still work? I havnt been able to check yet!
  15. quattrojames
    14,050
    577
    I doubt they do.
  16. S3 GAZ
    S3 GAZ Member
    381
    17
    £10 ish from audi. 10mins to fit and break your back when your upside down with your head in the footwell lol
    When i did mine. The switch is located on the metal arm of the brake pedal. Just unclip wiring connector and remove the switch. the new one will probably look different as mines did but its probably an upgraded design.
