...Help, electrical / brake lights issue nightmare!
Maz Oct 18, 2011
  1. Maz
    Maz Moon is made of green cheese
    1,002
    10
    Evening all,
    It's cold, dark, my hands are shredded and I'm about to set light to the car if i can’t get it sorted.
    This all started with the little bulb warning with the x in the middle light up on the dash this past week. I noticed the passenger side brake light wasn't working. Tried to change it over the weekend, it worked for a second then stopped working after I’d bolted everything back up again, typical. I have a mac sub back there as well so that makes things even more tricky as there isn’t enough room to access the bulbs without taking the rear lens off.
    Thought the bulb may have been faulty so picked up a few more today and attempted again, still no luck...
    At the moment when I press the brake pedal with headlights switched off the passenger side still doesn't work. The drivers side brake light and the high level one work fine although it also flashes the front drivers side beam when the pedal is pressed... lol
    With headlights switched on the passenger side not lighting up at all but the drivers side and high level brake light stay permanently on.
    …I’m thinking it’s either got to be crappy bulbs or brake light switch, what do you guys think?
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    Have you scanned the car? Normally VCDS will flag up if the brake light switch is at fault.
  3. Maz
    1,002
    10
    No, don't have it. :(
    Thing is I changed the brake light switch early this year, it can't have failed already???
  4. Westy
    17,443
    1,105
    To be honest mate if it was the brake light switch all your brake lights would be behaving the same, as in none of them lighting up when you press the brake pedal.
