Help, drivers window stuck down.
Stu-pid Jun 1, 2014
  1. Stu-pid
    Stu-pid Member
    84
    As per the title when I'm trying to put it up I'm getting a crunching noise from the motor or behind it where I can see something blue there. Any ideas how to get it up?
  2. Stu-pid
    Stu-pid Member
    84
    After searching it seems like the blue regulator has died on me.
  3. Greg190t
    Greg190t Guest
    Pop the door trim off and internal membrane, unbolt the glass and lift it and secure with a piece of wood etc!
  4. Stu-pid
    Stu-pid Member
    84
    I've got it up now duck taped in to place till my new regulator comes. Just watched this http://youtu.be/1YHB1y2lZrs
    Looks I will have a fun evening this week when it arrives
  5. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,300
    393
    From experience of these in golfs, Passat's and my S4, buy the original equipment, not the aftermarket version or kits.
    It will cost you less in the long run, trust me!!!!
  6. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Buy a used 2nd hand one.
    I have been through 3 aftermarket kits, two from ebay, one from eurocarparts - they don't last long!
  7. Stu-pid
    Stu-pid Member
    84
    I've got one with a 2 year warranty so it will be fine as I'm not planning having it that long tbh
  8. AlexGSi2000
    1,464
    199
    The first one I had from ebay lasted about a month - the replacement they sent lasted for about 2 weeks!
  9. GeoffDunk
    1,300
    393
    OEM only on this part, they all go on all the VAG models and OEM is the only way to make them last. Buying a second hand part that gets so much use is also false economy.
    Is it OEM, 2 year warranty will get it replaced but you still either pay for labour either out of you own pocket or you own blood, sweat and tears?
  10. GeoffDunk
    1,300
    393
    This is all too common sadly, New OEM only for this part all day long.
  11. Stu-pid
    Stu-pid Member
    84
    I had already ordered it last nite so just going to live with now. Being a coach-builder I can't see it causing me to many issues to fit it
