HELP - drivers side door won't open from the inside!
Shaq12 Jan 7, 2013
  1. Shaq12
    Shaq12 Drive it like its hot!
    53
    9
    Hi all,
    Not posted in this forum for ages but hope you might be able to save my life.
    Borrowed the girlfriends 09 reg TT roadster this morning to get to work. Unlocked the car on the drive via the keyfob, lights flashed, internal lights came on, heard the car unlocking BUT the drivers side door would not open from the outside. Passengers door opened fine and I could open the drivers door no problem at all from the inside. The drivers door handle outside is not loose, it still feels the same as the passengers one. Also if you put the key in the lock on the drivers door and turn it doesn't open the door either!
    I seem to remember a similar thing happening to a VW Golf I had years back but can't remember what the issues was and how I fixed it! So any ideas, suggestions etc. before I reluctantly have to take it to Audi... and/or confess what's happened!
    C
  2. hades-
    9,480
    646
    just tell her it was ok when you used it
    things go wrong
    or id take the door panel off and check in there.
