Help DPF Problem on my Audi A4 S Line 58 reg
carlsjoe1 Feb 11, 2013
  1. carlsjoe1
    carlsjoe1 New Member
    10
    Hi,
    Gotta problem with my DPF/Engine Warning light coming on for the last few weeks, just had the RAC out to reset fault code High Pressure Sensor fault, could it be the Sensor or is my DPF plugged, is there anything i can do barr go to Audi to get my pants pulled down.
    Carl
  2. NHN
    29,331
    1,716
    Welcome to the forum Carl.
    TBH we need a proper vcds scan of the car, then we can maybe offer better guidance, but you could try a forced regen again using vcds or if its the presssure sensor, then needs investigating/replacing asap, as it may cause more issues if not detecting proper levels.
  3. carlsjoe1
    10
    what other problems could this cause if i keep running it.
    thanks
    carl
  4. NHN
    29,331
    1,716
    If the pressure sensor isnt detecting correct levels, it may clog up & not regen or regen to often when not needed, so you never know it could damage the dpf itself to the point it cant regen maybe.
    I dont know the mechanisms fully employed for this & if a sensor goes wrong, does it auto regen on every drive or not to make sure its cleaned anyway, but for me I'd get it looked at asap to be safe on your pocket mostly.
  5. carlsjoe1
    10
    Thanks for your help and a bit crack, what do you think of removing the Dpf as dont do much motorway driving now.
    Thanks Again
    Carl
  6. NHN
    29,331
    1,716
    Bit crack?
    Hey personal choice, removal does help, but also helps your pocket loose some weight lol, but overall guessing its peace of mind aswell, talk to a proper tuner about this, iirc Rick@unicorn do this fairly often, maybe ask him.
  7. carlsjoe1
    10
    not that crack !
    is he on here is he.
  8. NHN
    29,331
    1,716
    I meant, what does "BIT CRACK" mean?
  9. carlsjoe1
    10
    its what the scousers (people from Liverpool) say for talking, Thanks Again
  10. NHN
    29,331
    1,716
    Kop?
  11. carlsjoe1
    10
    haha yes
  12. NHN
    29,331
    1,716
    Good or I'd have to get you banned :p
  13. carlsjoe1
    10
    haha ive left a msg on Ricks Wall :sm4:
  14. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,255
    586
    Hi Carl,
    thanks for the message, I'll send you a PM and explain your options.
    Thanks, Rick
  15. carlsjoe1
    10
    Just an update on this I've been to the tuning centre today and had the fault checked and its a sensor fault so hopefully this will be all fixed Thursday
  16. carlsjoe1
    10
    All fixed so happy days and cost £100 instead of £500 thanks seedox tuning in leechmere ind est Sunderland : )
