help: DMF FOR DSG 2.O TDI 140BHP
ukguy May 20, 2012
  1. ukguy
    ukguy New Member
    Hi all...
    i need to get new DMF for my dsg... and i have been told i need to replace the clutch at the same time?
    i cant seem to find where to buy the dmf and clutch kit for the dsg... can anyone direct me to a few different sites?
    mine is a 53plate audi a3 dsg.
  2. ukguy
    ukguy New Member
    pls anyone?
  3. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    Have you tried Eurocarparts?
    Not sure about having to replace the clutch at the same time with DSG.
  4. hp88
    hp88 New Member
    Have a look on eurocarparts, they usually have some sort of discount code for Clutch and DMF parts. Im not familiar with the DSG box but it's common practise to replace both parts to save yourself some money on the labour, I was told to do the same with my BMW.
  5. Rhyso
    Rhyso Well-Known Member
    1,482
    304
    As far as I'm aware the DSG has clutch packs and not a traditional clutch.
    The idea is these last the life time of the car.......
  6. A3SBQ
    A3SBQ A3 SportBack 2TFSI quattro DSG
    438
    68
    I have read some were that the clutch is ok but the DMF can warp on earlier models
    Might be a good reason to upgrade to stronger units from HPA Motorsport in Canada.
    This if you plan to get more power
  7. tabernac
    tabernac New Member
    I got the same issue.. Needs new DMF but Does the DSG clutch pack need to be replaced at the same time?
    have been told the clutch pack swap is a job that only a few specialists or the steelers can do, and it's likely to be expensive.
    Can anyone advise on how long do the original clutch packs last?
  8. Sayam
    Sayam Well-Known Member VCDS Map User
    2,703
    631
    On DSG you just replace the flywheel
    Clutch kit and flywheel applies to manual gearboxes
    My DSG flywheel was around £570 from TPS just for the part
  9. Yolo_8p3
    Yolo_8p3 Active Member
    330
    41
    As said above my mate has replaced just his dmf and not his clutch on his dsg
  10. tabernac
    tabernac New Member
    Ok thanks all..
    Final question can the DMF being on its way out cause a stutter when pulling up a hill In 4/5/6 gear or in any High torque situation...
    So the flywheel slips not the clutch / gearbox?
    Noob question but it seems every technician I talk to about it seems to have a different opinion.
  11. Sayam
    2,703
    631
    The way I diagnose mine is knock/rattle on idle with box in N that gets worse over time
