Help - Dipstick broken - piece dropped into dipstick pipe
spiker Oct 7, 2010
  1. spiker
    spiker usually growling at something
    200
    Just topping up the oil and as I removed the dipstick the top yellow plastic had cracked and I believe a piece fell into the dipstick pipe
    The dipstick will not replace - something (probably a piece of the yellow plastic) has lodged in the pipe
    How difficult is it to remove and clear the pipe ?
  2. sportstractor
    sportstractor Chugger
    2,709
    the pipe pulls of, but may break doing so. They go mentally brittle and I think most people have a bit of yellow plastic floating about in their oil
  3. Sant.
    Sant. Member
    50
    If you need a new pipe, It's called a dipstick guide tube/funnel and I believe the part number is 06A 103 663 B. It's £3.14 + VAT from the main dealer, or there's always the scrappy..
  4. spiker
    200
    Cheers fellas - thats a lot of help
  5. bhavin1986
    bhavin1986 BBP
    464
    I had to buy one earlier this week after the same thing happened to me. £3.69. Just yank the old one off making sure to remove all the bits of plastic inside the tube as well as the outside.
  6. spiker
    200
    ok so when you say 'yank the old one off' does it literally pull off without any tools ?
    Is fitting straightforward without a ramp ?
  7. 1animal1
    9,978
    yes very easy, its just a bitch to get on, when you think its on give it a quick tug and i bet it comes off again :)
    you need to hold near the base on push firmly down maybe the odd twist...otherwise it will just sit on top of the metal pipe
    one last thing, make sure the inner pipe has been removed before putting the new one on otherwise you'll be pressing down and nothing will happen
