help coding instrument 17 cluster made a mess!!!!
matt a4s line Jun 24, 2012
  1. matt a4s line
    matt a4s line New Member
    24
    Hi, I was wishing to simply remove the seatbelt chime using my diagnostic computer, i changed the code without taking note of the orginal code (blonde moment) and i have successfully removed the seatbelt chime but now i have fuel warning light on and only showing half of what it should be on the guage, also message press clutch pedal to start engine is displayed.... what have i done and how do i fix it?. I am very confused over all these codes tbh. my code now is 0-1048575, you imput the new code under coding right?. please help really pissed now and its looking like a trip to the stealers!!!!!"
  2. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    What operating system are you running and is it a genuine cable?
    You can revert to the old code which I will tell you if you mention your OS.
    XP - My Computer -> usually C drive -> Rosstech -> VCDS -> Debug -> CodingLog.txt and look for Address 17
  3. matt a4s line
    24
    I am using autoboss diagnostic tool, not vag. maybe thts where my problem lies???? thanks
  4. a6_chris
    1,883
    160
    Oh, no idea then, sorry!
    Where abouts are you?
  5. matt a4s line
    24
    I am in NI outside belfast, do u know anyone who can help me out?. I take it the dealers would be able to fix this even tho i altered the code? thanks
  6. a6_chris
    1,883
    160
    Lucky, I'm on the North coast - I'm away most of this week but if you could wait I could probably help you out?
    Agnews can restore the car to factory settings although they will probably charge an hours labour - you can also try Walsh Motors in Belfast too to restore your original coding WALSH MOTORS - Home
  7. matt a4s line
    24
    hi, where abouts on the north coast?, you wouldnt be about tomorrow by any chance as i am heading to the north coast for an appointment theres a few quid in it..... yea agnews 1 hour labour prob £90, its my own fault shouldnt have messed about with it!!!
  8. a6_chris
    1,883
    160
    Just outside Coleraine - I actually go early tomorrow morning, although I will be back in Belfast on wednesday evening if you're about then if it helps?
    If you're really stuck - try these guys in Coleraine - J W Service Centre
    Ex VW master techs so they will know what they're doing - wont be dear either.
  9. matt a4s line
    24
    aw ok no problem. i am working to 6pm on wed, what time would suit you?, I am unsure what I have actually done to the car the date format and time all changed as well lol, i think its set in another country... would it be easy for you to fix?, how will we be able to determine the code?
  10. a6_chris
    1,883
    160
    when its plugged into vcds a window will open telling you what the coding is for the module and the coding for the module - doesnt take long to do, a few minutes at most.
    ill get back to you on the time .. ill still be on my phone
  11. NHN
    29,522
    1,766
    Didnt you note your original coding, if so just return it to this.
  12. matt a4s line
    24
    its not the soft coding number by ancy chance? i have the details for soft coding, shop imp, shop wsc, and extra geraet all under vehicle information. maybe all i need to do is copy the soft code in?. thanks
  13. a6_chris
    1,883
    160
    Yea it's the soft coding number
  14. matt a4s line
    24
    ok thts great, my soft code number is 0006441 does tht look correct?thanks
  15. a6_chris
    1,883
    160
    Yep looks like a soft coding number to me
  16. matt a4s line
    24
    sory to be a pin, but you will enter the soft code number in the coding section? exactly like this with no spaces or - 0006441 many thanks and will let you know how i get on...
  17. a6_chris
    1,883
    160
    just the 0006441 and you should be grand
  18. matt a4s line
    24
    worked a treat cheers.... thanks for all your help !!!!
  19. a6_chris
    1,883
    160
    no problemo!
