HELP - Clutch Problem
Smillie13 Apr 16, 2013
  1. Smillie13
    Smillie13 Member
    933
    45
    Hi Guys,
    My clutch has been slipping today in both high and low revs and refusing to go into 2nd gear from 1st, will go from 3rd to 2nd no problem.
    Do you think I need my clutch replacing and will I have to renew my flywheel as well.
    My engine is a 1.9 tdi - engine code AVF will my car be DMF or SMF ?
    Thanks Susan
  2. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    Hi, sounds like the clutch is on its way out. Mine is an AVF and it has a DMF but I only replaced the clutch when mine went 6 months ago, I've had no problems with it since. As long as you aren't getting any vibration from the DMF then it should be ok. I would replace it sooner rather than later though.
    Smillie13 likes this.
  3. Smillie13
    Smillie13 Member
    933
    45
    Thanks, haven't felt any vibration through the clutch so hopefully the flywheel is ok. I'm going to replace the clutch very soon lol
  4. jerry,b6
    jerry,b6 New Member
    9
    bigger clutch and flywheel on the avf engine,,,240mm disc you'll need
  5. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Similar issues as to what's happening to mine on the 2.5tdi. Really difficult to get into gears and generally unpredictable.
    It's going in for a new clutch, dmf, slave cylinder and gearbox oil at the end of the month, so hoping things will get sorted.
