Help! clicking noise coming from wheels on near enough full lock
melon454 Feb 16, 2012
  1. melon454
    melon454 New Member
    23
    I have just put some 225 40 18 tyres on my A3 quattro sport and now when going round tight corners i hear a clicking noise, anyone got any ideas? ive had a look through the forum but none of the other posts seem the same problem
  2. hades-
    9,482
    646
    if its on full lock
    id say cv joints
  3. melon454
    melon454 New Member
    23
    its when ging round 90 degree corners but its only done it since ive got the new wheels
  4. hades-
    9,482
    646
    have you checked if the wheels are catching anything ?
  5. melon454
    melon454 New Member
    23
    ive just been and checked and it wont do it on full lock pulling off only when going round a corner accelerating ,at constant speed it wont make a noise
  6. jay1601
    jay1601 Well-Known Member
    1,347
    73
    i would say the same as bez tbh. either rubbing or CV is going/gone
  7. Customboy
    Customboy Active Member
    831
    43
    Does sound like a cv joint or bush problem have u checked ur power steering fluid and made sure that's ok?
  8. melon454
    melon454 New Member
    23
    ill check that inmorning, cheers for your help all of you ,guess if its not powersteering fluid ill take it to the local garage for them to look at it
  9. Jimgrim77
    Jimgrim77 Member
    957
    21
    Its probably the front wishbone bushes. I have a very similarly described noise and when i checked they had perished.
    I have bought power flex bushes to go on the front wishbones and that should sought it.
  10. melon454
    melon454 New Member
    23
    it was the cv joints, which i bought a recon/new set for 30 quid and fitted myself in 3 hours after a garage wanted £200 to fit!!!!
