Help changing side light bulbs w5w
afcjay Jul 6, 2011
  1. afcjay
    afcjay Member
    437
    Replaced my headlight bulbs for some whiter looking Philips bulbs which was easy enough to do but now im looking to replace the side light bulbs also (w5w) but cant get my hand into the unit
    Can anyone tell me what the best way to go about changing them is and do they just pull out or twist/pull out?
  2. Ads
    Ads License to drive
    8,230
    612
    They just pull out.
    Best way to do it is grab the wires and pull out. DO NOT yank the wires, just pull softly until the slack is taken up and then firmly and evenly pull the bulbs out.
  3. FranA3
    FranA3 FMDETAILING Site Sponsor Regional Rep Gold Supporter Team Brill Red Audi A3
    7,262
    357
    what he said , they just pull out matey can be a bit of a pain to get back in but if you look through the front of the light you should be able to see the bulb when you are trying to line it up so it will go back into the hole
  4. afcjay
    afcjay Member
    437
    thanks people ill get on them tomorrow
  5. FranA3
    7,262
    357
    once yo have done them once you will do them so easy the next time they dont take long at all to do 5 mins tops
  6. mike foster
    3,967
    When putting them back in switch the lights on and look in from the front. It will help you align the bulbs with the hole.
  7. afcjay
    afcjay Member
    437
    thanks for the replys/advice
  8. Bailey
    Bailey Member
    247
    15
    Sorry to revive an old thread but I had a look at changing mine tonight and just wondered which way is easiest to go in? Is it through the main headlight compartment or the dipped headlight compartment?
  9. mike foster
    3,967
    Main beam (inner) light. The two compartments are totally separate assuming you have halogen lights.
  10. Bailey
    Bailey Member
    247
    15
    Ok thanks, I will give this a shot tomorrow night after work when I have got some light. Is it an "ok" job to do? Is there any special trick to doing it. From what I looked at in my car and read earlier it looked a pain in the ****
  11. sliced
    sliced Drive safe, stay alive.
    1,568
    335
    You can always use a long this screwdriver flat head, as long as it reaches to where the sidelight is, just pry it out. It pops out very easily that way.
  12. mike foster
    3,967
    Just use your fingers to grasp the wires firmly and pull slowly backwards. Do not 'yank' the cables - firm pulling will pop them out easily.
    When replacing I find it easier if you actually turn the light on and look through the front glass to line the bulb holder up with the hole in the reflector.
  13. Bailey
    Bailey Member
    247
    15
    Thank you for the tips, I will try this perhaps on my lunch break or tonight after work :)
  14. K2000
    K2000 Member
    41
    You could also try using an old coat hanger (this is what I did although I had to bend the hanger slightly to make things easier).
  15. Bailey
    Bailey Member
    247
    15
    Just tried doing this on lunch break at work and I couldnt do it. Tried with long nose pliers and still couldnt get the blighter out.
    I didnt pull too hard in case of breaking it. I can get at the unit but when I pull slowly it doesnt budge. I also tried with my hands too :(
    Bailey
  16. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    Weird they didn't come out that easy as although awkward mine were actually quite loose both getting them out and once I had put them back in.. Fiddly but shouldn't have to use pliers.. Stupid design though in my opinion
  17. quinnii
    quinnii Active Member
    328
    94
    To be fair the wires are fairly secure in the holder, I replaced both of mine yesterday. Just give them a twist first then they should come out a bit easier, I had to give it a little tug by the wire as they were stuck solid. Probably not the best practice but it got them out.
    Also on a side note when I pushed my light back in it went with some force and bulb actually came out of the holder and ended up on the inside of the light unit! Luckily the bulbs were metal bodied LEDs and I had an extendable magnet handy!
  18. OVRA3
    1,079
    80
    You never know when you might need an extendable magnet I always keep one on my person ;-)
    Seriously though lucky as I can't imagine getting it out with that would be easy!
  19. mike foster
    3,967
    Be firm with them and gently rock the wires from side to side first. They will come out, you just need confidence !
    You should not need to use pliers
  20. Bailey
    Bailey Member
    247
    15
    In the end my mate (mechanic) managed to do them easily for me, it was a bit fiddley and even he said they are a stupid design
    Thanks for all the help guys
    Bailey
