Help!!!Car wont start
l1ons81 Feb 3, 2013
  1. l1ons81
    l1ons81 Member
    49
    Hi
    Hope sum1 can help, Last drove my car on friday, havent touched it all weekend. went to drive it today and it just wont start, Battery is full. However when i have looked at vagcom. The following errors have appeared
    17075 - Fan 1 control circuit: short to ground
    19558- motor for intake manifold flap (V157): no signal
    I checked fuse f8, this was blown, i have replaced the fuse. tried to start and it wouldnt,check the fuse and it was blown again.
    It wont start and im stuck on what to do..
    Help Please
  2. NHN
    29,510
    1,764
    Which year/engine?
    Check the intake manifold flap has not seized as they sometimes the older ones have plastic teeth that break internally.
    I would disconnect the fan unit, replace fuse, turn ignition on, clear all faults, then see if the intake flap is showing a fault or fuse has blow again.
  3. l1ons81
    l1ons81 Member
    49
    How do u disconnect the fan unit mate?is that the plug nxt to intet manifold?
    Cheers mate
  4. l1ons81
    l1ons81 Member
    49
    2004 2.0tdi mate,how do i check if the manifold flap has seized
  5. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    I believe that the fuse that supplies the engine fan is the same one that supplies the intake manifold flap. If the intake manifold flap is closed, the engine should not start (it cut's off the air from the manifold). It might be useful to first of all disconnect the fan, replace the fuse and see if it starts. If the fuse blows again, then the fault lies with the manifold flap motor. If it starts, then the fan needs attention/replacement. Good luck.
  6. NHN
    29,510
    1,764
    Yeah big connector behind the fan unit, cant miss it tbh.
    You'll need to remove the imf & open it up to check what its like inside, but try removing the flap & moving the flap by hand 1st, if it doesnt move then its seized.
  7. l1ons81
    l1ons81 Member
    49
    Where do i find the IMF,can i move the flap without taking the part off?
    U got any pics for the fan plug?not very mechanical
  8. NHN
    29,510
    1,764
    Open bonnet, look directly down betwee front of engine & the fan unit & you will see the 2 fans & iirc slightly on the left at bottom of the fans there's a chunky connector there to unplug.
    The flap is fitted to the front of the engine, with the intake big fat pipe coming up towards it from bottom.
    TBH if you're not that minded, then maybe ask someone else to do it as you could cause more issues, no offense.
  9. l1ons81
    l1ons81 Member
    49
    Ok thanks for the advice, i know where the flap is now.. Do i have to remove the whole part to see if its seized or is there a way i can check while its still on the car?
  10. NHN
    29,510
    1,764
    If you can get a finger up inside to move the flap, then yeah try that.
  11. l1ons81
    l1ons81 Member
    49
  12. NHN
    29,510
    1,764
    Have you actually tested anything yet?
  13. l1ons81
    l1ons81 Member
    49
    Nah, too dark.. Just wondered if thats the one i need if its the manifold flap
  14. NHN
    29,510
    1,764
    Too dark :p, tbh with a torch during dark its allot easier to see where the bits are, as daylight can distort things in engine bay :)
    It looks like that, but you have to check part number 1st, but condemn a system before ordering of course.
  15. l1ons81
    l1ons81 Member
    49
    Ok mate.. thanks for the advice and i will keep you updated.
  16. mike foster
    3,967
    Ha ha, that's a beauty answer mate !!!!! lol
  17. NHN
    29,510
    1,764
    I cant believe I didnt see the humour in my reply until now, thats kinda sad like lmao, re-reading it actually is funny as hell, maybe its because there's a drought on lmao.
  18. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,516
    10,589
    Omg, Nigel, that was a priceless reply, i nearly spilt my tea. Lmao. :) x
  19. NHN
    29,510
    1,764
    lmao just reading it again, priceless lmao
  20. JudderMan
    JudderMan Well-Known Member
    1,010
    168
  21. l1ons81
    l1ons81 Member
    49
    Right boys, tested it with the fan off and still didnt start, so i took the manifold flap off, and the value inside is so hard too move, could this be the reason its blowing the fuse?
    I'm just about to order new part.. do you all believe this is the reason the car wont start?
