help car wont start think fuel prob
jim s3 Jan 2, 2009
  1. jim s3
    jim s3 Member
    321
    right then guys i had the car running fine for the last few weeks but now when i get in the car to go and start it i cant hear the fuel pump prime and car wontfire up what could it be????i took the fuel lines off in the engine bay and put a cup in the lines thinking when i go to start the car fuel would come out but nothing....
    fuel pump?
    fuel pump relay?
    fuel filter??
    any help would be good oh and no fault codes come up..
  2. Purple Princess
    Purple Princess Moderator Staff Member Moderator
    1,044
    Fuel pump realy would be the easiest and cheapest to check. You could try bridging the connections just to see if the pump will run, also i assume it is sparking as that would rule out crank sensor etc.
    I assume the imo light goes off on the dashboard.
  3. jim s3
    jim s3 Member
    321
    yeah everything else is fine... it done even prime.. where is the relay?????
  4. Nilz
    11,329
    876
    Would it be the ignition coil at all??
  5. kevandalice
    kevandalice Member
    69
    Could be the crank sensor (engine speed sensor) if you're not getting a spark, which i guess you're not as you put some fuel through
  6. jim s3
    jim s3 Member
    321
    changed relay and still nothing tested the fuel pump and that works but no fuel getting through to engine the pump doesnt prime when turn keys..
    it doing my head in now going to check that i have a spark now
  7. jim s3
    jim s3 Member
    321
    got fuel now but no spark lol where is the ignition coil??
  8. kevandalice
    kevandalice Member
    69
    Have you scanned the car? When my crank sensor failed 2 weeks ago it didn't show up on vagcom until the day i fixed it which was 3 days after it wouldn 't start, even though i turned it over every day. If it is the crank sensor that is faulty, it will cost £30 from your local parts place
