HELP - Car in very bad way....
tobycruse Jul 12, 2009
  1. tobycruse
    tobycruse Member
    289
    I just went out for a drive, a quick blast near by on a dual carriage way. Got to a set of lights and pulled away, the car stuttered a bit and then got worse.
    The car will now not go past 4000rpm and will only build 5psi of boost. I have had a quick look in the engine bay and all the hoses seem to be secure.
    The car will still drive but it feels like 80% of the power is missing and someone moved the limiter to 4000rpm.
    What could this be? Really worried its something bad.... Any advice would be much appriacated.
  2. NHN
    29,551
    1,777
    Limp mode by sounds of it Toby, get vagcom on it, disconnect battery for few mins then reconnect see if it does anything to rectify.
  3. tobycruse
    tobycruse Member
    289
    The engine warning light hasn't come on, still worth disconnecting the battery?
  4. NHN
    29,551
    1,777
    Wont do it any harm mate, but get vagcom on it, assume you have vag.
  5. tobycruse
    tobycruse Member
    289
    There also seems to be a tapping/knocking noise coming from the engine bay once every 6 to 8 seconds. Sounds a bit like metal expanding and contracting with heat but I have never heard it before.
  6. A3simon
    A3simon Active Member
    982
    40
    i had something similar when i fitted the autotech pump internals as they seized up might be that
  7. tobycruse
    tobycruse Member
    289
    Just disconnected the battery for 3 minutes, the car is still in limp home mode. Now the car says there is an ESP fault and power steering fault, but these come up when the battery is disconnected I'm sure. Still no fault codes coming up, any other ideas guys?
    Should i take it back to Audi or AmD to fix?
  8. S3 Big Andy
    S3 Big Andy Stealth Beast Baby Yay
    725
    Amd sounds like a turbo problem, hope its not blown!
  9. A3simon
    982
    40
    yeah those lights always come on when the battery has been disconnected
    it does sound like the problem i had with the autotech pump
  10. tobycruse
    tobycruse Member
    289
    Ok, what ever it is. Is the car ok to drive in this state?
    I'm getting DV broken from one forum and pump broken from another!
  11. hollows wife
    hollows wife Well-Known Member
    1,404
    164
    sounds like a turbo problem to me no boost lack of power
  12. tobycruse
    tobycruse Member
    289
    It takes about 40 minutes to get to AmD, is it ok to DRIVE the car in this state?
  13. A3simon
    982
    40
    should be fine if you dont have any warning lights and you keep it low revs
  14. tobycruse
    tobycruse Member
    289
    Thanks Simon, i have been doing just that and it seems to be ok.
    Will take it to AmD first thing tomorrow, will write up as soon as i know what's wrong! Finger's crossed its either the DV or the HPFP.
    Thanks for all your help guys, will report back soon!
  15. A3simon
    982
    40
    if you take it above 4k does it feel like the car is stuttering and wont rev any higher
  16. Iggu
    Iggu Active Member
    1,229
    Toby - I've just replied on the other forum but its a 10sec job to check the DV. If you have the green spring with your Forge it may have collapsed (you need the yellow one for remapped cars). If so its a £6 fix ... at least checking it now would rule this possibility out (or in).
  17. N8
    17,163
    719
    Hope you get it sorted Toby.
  18. tobycruse
    tobycruse Member
    289
    Just had a look inside the DV, you are right, i have the GREEN spring. Though the spring looks perfectly ok, it doesn't look like it has collapsed.
    Also, upon starting the car, it turns over about 3 to 4 times rather than starting straight away. Would this be a symptom of the DV spring as well?
    How do i get the yellow spring?
  19. tobycruse
    tobycruse Member
    289
    Just ordered the yellow spring from Forge...... Hope its the solution!
  20. bluequattro
    bluequattro Member
    411
    good luck toby hope its something silly m8
  21. Ash B
    Ash B Well-Known Member
    5,831
    85
    Hi Toby
    Sorry to hear about your problem with the car. Hope that its nothing major and just that you need a yellow spring from forge. Let us know how you get on at AMD.
    Ashley
  22. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,487
    Can you chuck the the original DV back on to remove that issue from the equation?
    The metallic sound doesn't sound promising.
    Be fascinating to see what this is, and keep my fingers crossed for you that all is well after the diagnosis. We don't want 2 S3's going down in as many weeks.
  23. s3
    s3 s3
    50
    i would say this is definately a turbo issue. I had exactly the same thing happen just before xmas last year. I was driving normally and then there was no power, was very flat, revs very slow to build up, think i has 2psi boost.....
    I continued tried everything and the more times i tested the car on the road and the engine was running it started to get noisier and eventually so noisy i had it towee in the garage.
    If i was you i would leave driving to a minimal and maybe get it towed in etc.....
    I feel for you as i know exactly how i felt last year when mine blew.
    good luck and keep us informed
    andy
  24. kaz219
    kaz219 Active Member
    1,808
    If its a turbo issue, you could knacker the engine by driving it.
    When my turbo blew on my tdi, a scraping noise would come from the engine every few secs - the shaft had snapped...
    I wouldnt drive it, keep an eye on oil and tow it down to AMD (if the DV issue doesnt fix it).
    Hope you get it fixed..
  25. Broken Byzan
    13,237
    465
    When my turbo blew using the car to travel 1.5 miles to get to a safe place to stop, used the whole sumps worth of oil. So be aware of that if you choose to drive it.
    I honestly cannot see the spring making any difference as the fault would more likely be not holding boost, unless the spring was FUBAR which you say it's not.
    The poor starting can be attributed to safe mode, you need to get the car scanned and post results. Maybe you have dropped a coil pack? is she still running smooth?
  26. kaz219
    1,808
    There's the issue of the oil usage and the issue of the debris from the turbo going back into the engine and wrecking it - i honestly wouldnt drive it mate...
    I turned mine off straight away and debris still got to the intercooler (there were big chunky bits too - a whole blade of the propeller!)
  27. NHN
    29,551
    1,777
    Have you scanned it with vagcom as yet Toby?
  28. S3 Big Andy
    725
    It could be a stock map turning back on I did have this proplem with mine once I had disconnected the battery, and mines revo!
  29. tobycruse
    tobycruse Member
    289
    Odd that when i got it back from Audi it was running fine. Only 2 days later did the fault appear. I did tell the garage NOT to re flash the ecu.... Im sure if they had the car would have been like that out of the garage? Anywho, AmD have already deduced that it isnt a software problem..... The search continues......
  30. NHN
    29,551
    1,777
    So thats a no then???
  31. Iggu
    Iggu Active Member
    1,229
    Just had a thought Toby - you been through any deep puddles recently and kept your foot down ? Possible hydrolock of the turbo given the Forge CAI you have ?
  32. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    whay about a coil lol ... i no it may sound daft but my car ran like a bag of poo when one went ...but as your saying its the turbo ??? you got a ny lights on the dash engine light or anything
  33. tobycruse
    tobycruse Member
    289
    No engine warning lights. Just wont go past 4000rpm and about a 90% loss of power. A bit like driving a 1.0L!
  34. 10blazin
    3,301
    im really cack on cars but when my coil went , only one by the way it was like a 1.4 to it was really bad i thought the car was dead serious , and it turned out to be a 40 pound coil i couldnt believe it when roadside turned up went pop done and drove off i was one happy man .....
  35. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    I somehow completely missed this thread Toby.
    I knew a guy who complained of a similar problem (although I don't think as bad) and as has been said above it turned out he had the wrong spring in his DV. He fitted it himself and didn't know any different.
    Has yours arrived yet?
  36. gavsteryoung
    gavsteryoung Member
    57
    as you have the 09 facelift.... do the revs get stuck at the same rpm that the engine does if you just leave it in neutral and put your foot down?
    Could it be related to that?
    Not sure how this rev limiter works, wheather there's an actual micro switch or if it detects your in a gear... does the DIS show what gear your in still?
    Did the older non facelift S3's have this torque limiter in 1st gear?
  37. tobycruse
    tobycruse Member
    289
    The car is being diagnosed today by AmD. I pray it isn't something complicated, big and expensive!
    Will report back as soon as I hear anything....
  38. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    good luck for it mate,
  39. tdisportuk
    tdisportuk Member
    460
    good luck mate hope its not major!
  40. Scott
    Scott Well-Known Member
    1,306
    126
    any news mate?
