Help, Car cutting out.
daveking87 Jun 25, 2013
  1. daveking87
    daveking87 New Member
    Hello,
    Today I changed the rocker cover gasket and now the car cuts out at higher speeds and i have to turn the key to start it agian. All pipes and cables seem to be fine I am stumped, any ideas guys?
    The car is and S3 1.8t.
    Thanks in advance.
    Dave
  2. <tuffty/>
    22,268
    4,415
    Hi... have you plugged all the solenoids and valves etc back in properly? coil pack wiring loom earth on the top of the cam cover? connected hoses back as they should? checked for spilt hoses now that everything has been disturbed?
    I would also scan for fault codes as there could be some clues there too...
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Check wiring to the cam/crank sensor, if its when its warm, most likely the crank sensor is duff, or get it on the computer to be certain..
  4. daveking87
    thinking about its the earth cable for the wiring loom it has been put back on the cam cover but the the cover has been spayed lol i best try scraping some of the paint off where it connects
  5. daveking87
    Looks like that solved the problem, could anyone explane why?
  6. <tuffty/>
    22,268
    4,415
    Its a required earth for the coil packs.... without it the coil packs will struggle when loaded... have had an engine run like a bag-o-poo on cold start too...
