Help Car cut out while driving
Mark24a3 Nov 22, 2012
  1. Mark24a3
    Mark24a3 New Member
    24
    Need some help, was out in the car about an hour ago and car died whilst driving down road so started her straight back up then did same after about 500yards. Pulled up tried to start engine and all it did was try and start and not fire up. As I waited for me dad in the ranger to tow me back it started up again, but after a minute cut out and keeps doing this. Just before it cuts out every time the triangle warning light with the arrow going around the outside of it comes on.
    Before it started back up I checked the belts and they was both on. Next thought it could be fuel related such as diesel pump or injectors.
    Can anyone else think what it could be or had similar problems. The car is a 1.9tdi.
    Help!!!
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Not to up on soot chuckers but it sounds like a crank sensor,
  3. Purn
    Purn Member
    34
    Yup, second that.
  4. Sam_
    Sam_ Down under
    3,038
    480
    Mine's been doing this. Dodgy idle and sometimes just cuts out but starts straight back up again. Mine's a complete loss of power like the key has been removed or turned off though. Would it be the same thing?
  5. Mark24a3
    Mark24a3 New Member
    24
    Right will have to get busy this weekend and sort it. Cheers guys.
    I didn't notice irrational idling but it was just like the key turned off.
  6. Purn
    Purn Member
    34
    A bit of a long shot I know, but if you can your hands on an oscilloscope you could check the output of the crank sensor. You should get nice square wave, if it's shot just a line.
    When crank sensors f**k up it's normally when they are warm, I assume it doesn't do it from cold?
  7. Sam_
    Sam_ Down under
    3,038
    480
    Sounds familiar. Might have to try changing mine...
  8. BuuBBa
    BuuBBa Member
    133
    Mine did exactly the same last summer and the fault was the crank sensor.
  9. Sam_
    Sam_ Down under
    3,038
    480
    Looks like you have to remove the oil filter to get to it, is that right? I just done a service :'(
  10. s3dave
    10,110
    736
    No Sam you dont need to remove the oil filter but it is a ***** to get to...
  11. s3dave
    10,110
    736
    from memory it is a 6mm alen type bit you need
  12. Sam_
    Sam_ Down under
    3,038
    480
    Are we talking themostat levels of annoyance?
  13. s3dave
    10,110
    736
    ERM i would say slightly more,,, you can feel but you cannot see, once you get your bearings it is pretty easy...
  14. S3_OL
    S3_OL Active Member
    101
    41
    A bit more fiddly, I had the same problem last year on my Corrado 1.8T.
    GSF replacement was about £20 and served me fine.
  15. ruffrida
    ruffrida Well-Known Member
    1,926
    313
    Does your glow plug light flash? Usual sign for cranksensor on oil burners
