Help! Cant open the bonnet
kirilgit Nov 20, 2013
  1. kirilgit
    kirilgit New Member
    hello everybody!
    iam new to this forum, and iam not from USA so sorry for my english.
    i have an issue with opening my bonnet, its not opening.. the cable must fallen off from its shasies inside the engine bay.
    what is the way to open the bonnet when the intire cable mechanisem fail to work?
    i will be very thenkfull to any guidness or help..
  2. S3 GAZ
    S3 GAZ Member
    381
    17
    Have you tried opening it whilst someone else is pulling the handle inside the car
  3. quattrojames
    14,050
    576
    You can either break the grille, or pop the undertray off and use a long extension to get to the bolts from underneath.
  4. kirilgit
    kirilgit New Member
    the handle is not responding at all, even when i pull it and someone push the bonnet down.
    about the grill, i managed to take it off withput breaking it, but there is one bolt under the bonnet that is quite far and not easy to open. if i open it, i will be able to open the bonnet??
  5. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    as you have the grill off, use a small 10mm open end wrench to remove the 3 acorn nuts holding the hood to the latch,
    or
    push this latch to the right hand side of the car. (so drivers side if right hand drive, or passenger side if left hand drive)
    looking from
    underneath up.
