help broken the vacum of my inlet mainfold
harvey01
hi all I've the ken the vacum fitting from the left hand side of the inlet mainfold (the one closest to the front ) what's the best way to fix I. e drill it out and bond a new one in ??
If ur after a standard inlet manifold i have a spare one of a APY wih throttle body if u was interested will sell cheap as need space in the garage
They're not particularly expensive second hand so might be worth buying second hand over trying to fix yours, postage would probably be the worst bit unless you can find one locally. Where abouts are you based? someone on here will probably have one kicking around.
Or failing that just do the n249 bypass, i think most of my small vacuum outlets are blanked off on my intake.
that's what I was doing the fpr vacum is still in taked can I just tee in to that one ??
All the vacuums do the same, just drill out the snapped one, put a thread on it and locktight a bolt in there to seal it up
