Help Brake warning light
Daboyracer Mar 23, 2010
  1. Daboyracer
    Daboyracer Speed Freak
    51
    Need some advice please, i've got the red brake warning light the one with ! In the middle any ideas What could be wrong? The brakes are squeaking am going to have a look at the pads at the weekend just wondered if there was anything else i should look for. The fluid level is ok. Thanks damo
  2. Mike B
    Mike B Well-Known Member
    1,115
    40
    I think thats the fluid warning.Does it stay on or do you have the three bells when starting which is an electrical fault if the fluid is ok.
  3. Daboyracer
    51
    I get the 3 bells and it keeps blinking, what sort of electric problem could it be? Would it be the sensors on the pads?
  4. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    Abs sensor or abs module. You will need to get it on vag-com and see what it says.
  5. Daboyracer
    51
    I'll be getting the lead on monday for vag-com this sounds like it could be expensive
  6. mwarrey
    mwarrey Member
    280
    If it is the ABS ECU (quite common) you can get it repaired which will cost around £200 from someone like BBA-Reman. There are repair services on ebay which may be cheaper. (A new one is over £1000 when I last checked)
    Its not too difficult to take the ecu off yourself and send it off for repair. If you do a search on here or audiworld there are articles on how to do this.
  7. Daboyracer
    51
    would i not get the abs light come on as well if it was one of the above? hopefully when i plug it in i'll get to the bottom of this.
