Help :( - Brake Problem?
Daniel97 Dec 19, 2011
  1. quattrojames
    14,050
    576
    Can you link me to where they're saying that please?
  2. Daniel97
    Daniel97 Member
    137
    initial comments point to battery also but fluid is also a factor .. i have finally gotten my car back at lunchtime having been away from it with work for hours and hours so was able to check fluid .. bit dissapointed it was serviced 2 weeks ago and they ignored that?
    Either way i have fluid, battery and switch all on order!
    Please Help: Brake Problem :(-(
  3. quattrojames
    14,050
    576
    We've all got different opinions ;)
    In my experience if the light comes on in the situation you've described it's due to lower battery power and the ABS module rather than low brake fluid. Brake fluid level is of course very easy to check and eliminate.
    If you're doing the pedal switch too that will help, PM me your email and I can send you a pdf guide to do that.
  4. Daniel97
    Daniel97 Member
    137
    Top man!
    how much is an ABS Module? - And can i test that to see which of the 2 is the problem rather than buy both?
    PM on its way!
  5. quattrojames
    14,050
    576
    PDF sent.
    Fit the switch, if it doesn't help get the battery tested. If that's inconclusive replace it anyway and that should fix it.
    Don't stress on the ABS module, I've *never* heard of one go on an A4 personally.
  6. Daniel97
    Daniel97 Member
    137
    thanks chap!
  7. Daniel97
    Daniel97 Member
    137
    Parked facing the opposite way on the hill last night so i was facing the right way for this mornings journey and hey presto - no error?
    So if it is fluid related - it makes sense as the angle i was parked at this time would of told the car it was nice and full .. the other way - it COULD think its empty i guess ..
    Also was a bit warmer this morning and no frost ..
  8. quattrojames
    14,050
    576
    :tapedshut:
  9. hades-
    9,481
    646
    the sensor is on the bottom up down sideways the same
    does it come on when you go round a corner ?
  10. Daniel97
    Daniel97 Member
    137
    lol :p
    No mate?
  11. quattro tony
    quattro tony Member
    167
    I can definatly tell you that the yellow brake warning light is the pads low and the red one is the brake fluid/ handbrake light. I hadn't stated my a6 for 3 weeks and the red brake warning,light came on , beeped, It had never done it b4, the battery on mine seemed to turn the engine over as normal. so i looked at the brake fluid res and the level was a bit down, topped up and gave the sensor wire a wiggle and it seemed to do the trick, has not come on since. I know a lot of guys have experienced this fault and its the battery , but in my case it seemed more fluid related.
  12. a8 tech back
    a8 tech back Member
    198
    The voltage drop when cold cranking has nothing to do with the abs its draw at the dash insert and in most cases the battery is perfectly serviceable
    https://www.rapidshare.com/files/920574167/red_brake_warning_light_from_cold.doc
    to check simply press the check function on the dash when cranking and the fluid level warning will come on
    if the battery is in order and the fluid level is in order carry out the relay mod in the link to eliminate the spike
    I have the original battery and the mod carried out two years ago with no further issue
    If you think the battery is weak then test it and the cranking volt drop
    https://www.rapidshare.com/files/2920030305/Voltage_Drop_Testing.doc
  13. Daniel97
    Daniel97 Member
    137
    Ok, fluid just turned up in post :D lol
    Cap off and topped some up and the level hasn't moved?
    Theres like a plastic filter/sieve thing in the cap and the fluid level is now sitting above this BUT the actual line on the tank hasn't moved?!
  14. a8 tech back
    a8 tech back Member
    198
    gently lift the filter with a small thin screwdriver and the fluid will then enter the master cylinder chamber
    trust me it will
  15. Daniel97
    Daniel97 Member
    137
    okay job for after lunch! lift it though yeah?
  16. quattrojames
    14,050
    576
    Thats an interesting read, where is it from?
    It all adds up, except that most people I know who suffer the issue can cure it instantly with a new battery.
  17. Daniel97
    Daniel97 Member
    137
    doesn't work?
    just tried it and filter won't lift ...
  18. a8 tech back
    a8 tech back Member
    198
    it will you have to slide it down the side and lever it
  19. Daniel97
    Daniel97 Member
    137
    and it comes clean out? looks more like I'm going to snap/brake it tbh
  20. a8 tech back
    a8 tech back Member
    198
    This copy is from hst2, its been around for many years in the dealers or those who had the problem years ago (I dealt with more than a few)
    I did post it up 2 years ago on vwaudiforum but people don't search forums for answers do they lol
    Mainly 2.5 tdi b6 a4 cabs suffered the most and we used aluminium foil around the starter cable as we thought it was running to close the master cylinder in the plenum chamber
    The quick check is to press the check button on the dash when the red light comes on
    If it highlights fluid level then the mod is required unless you do have slow cranking
    You see the battery will be under greater load from cold start so it doesn't mean its goosed its just this drop in voltage when cranking creates the problem although the driver rarely complains of slow cranking speed
    X relief should by nature turn all un necessary consumers of for maximum cranking, so taking this circuit out briefly allow the signal to be interrupted and no more red brake warning
    At the time warranty refused to pay for battery's as they passed the cold crank test when returned to factory and battery's are only covered by warranty if they are consequential or a proven history of good maintenance ie not been sat on a pitch etc
    Most battery's prematurely age due to lack of maintenance and ironically that's due to sales pitches etc
    When you next visit a dealer take a look in the showroom and you will see the cars are hooked up to chargers discreetly
  21. quattrojames
    14,050
    576
    I've added those links to the DIY Guide's sticky, thank you.
    I've no idea what that is sorry..
  22. a8 tech back
    a8 tech back Member
    198
    The repair is from elsa win hst2 is the off line version for technical bulletin's
  23. marktdisport
    marktdisport Active Member
    1,195
    15
    clever info there bud mine defo was a dud battery in my case, original battery and the sells was all distorted and dry, new fitted and no more faults since
