Help brake problem at Westys and stuck
rhubarb4 Sep 16, 2012
  1. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,754
    188
    This is the problem stripped the calipers off and on fitting the new ones the nipple won't screw on to the existing pipes is there anything I'm missing to connect them up
    Cheers, Chris.
  2. badger5
    9,637
    2,073
    is the brassy looking one to the right the new one? M10x1 female fitting is what it needs to be
  3. rhubarb4
    1,754
    188
    Yes the one on the right is attached to the Porsche caliper Neil can't get it to thread to the existing like its too small, 11mm spanner fits both the original caliper and the new Porsche one
  4. rhubarb4
    1,754
    188
    As in spanner on the nut on the brake lines on the caliper side
  5. rhubarb4
    1,754
    188
    And 11mm on the hard lines from the car
  6. badger5
    9,637
    2,073
    in the picture the hardline is still attached to the old line.. so his has been undone yea, and wont screw into the porka line..?
    do i understand correctly?
    if you have any vernier calipers, measure both female parts to compare the internal diameters...
    M10x1 female union I have here measure 9mm inside diameter
  7. rhubarb4
    1,754
    188
    Cheers for the reply Bill unfortunately no vernier calipers is there another way to measure, yeah we have undone the lines both sides but the hard line won't screw inside the nut on the caliper almost like there the same size was wondering if there is supposed to be some kind of adaptor. Neil has took some photos of his and will post up to compare.
  8. Westy
    Westy Well-Known Member
    17,443
    1,105
    Bill, mine look like this:
    These are a set of your lines. It has that middle section that Chris doesn't have. I've got a feeling the guy who sold him the brakes has not sent him this piece.
  9. coatesy
    coatesy poking badgers with spoons
    1,920
    280
    ha quality, your lines are held in place the same as mine, man style !
  10. badger5
    9,637
    2,073
    you have'nt used the spring clips supplied...
    there is no middle section.. thats one piece crimped onto the flex line.
    The fitment of the hose should go thru the bracket on the car, squeazed in a little to close up its diameter to stop the female fitting from pulling thru and use the spring clip provided on the top nut...
    the fitting is m10x1 and measures 9mm ID with calipers, so the hoses on the porka brakes are wrong diameter or wrong thread if the male union on the car wont screw in
  11. rhubarb4
    1,754
    188
    Do you have an adapter to fit the Porsche lines from the caliper to the hard line of the car
  12. badger5
    9,637
    2,073
    No
    @ Caliper they would normally be the same M10x1, same lines as brembos, as weticles uses
  13. Westy
    17,443
    1,105
    Bill on my pic, that middle piece, does that come on your brembo lines? The reason I ask is because that part isn't on Chris' lines or on the OEM hose or the OEM hard line. Something's missing here!
  14. rhubarb4
    1,754
    188
    This is what I have bill to fit to the standard hard line on the car
    Cheers, Chris.
  15. badger5
    9,637
    2,073
    you know what my lines look like westie... you have some.
    i dont know what you mean by middle piece i'm afraid.. there is no middle piece..
    from caliper (my hoses) there's a male-male union, then 90' elbow crimped onto the line, and crimped at the other end of the line is the m10x1 female union.
    their female union must be some other thread is all I can guess
  16. Prawn
    11,719
    3,761
    yup, this 'middle bit' is confusing me too Westy, on your picture of your setup, there are only two parts, no middle bit at all!
    Looks to me like they might be the standard porsche lines you have
  17. Westy
    17,443
    1,105
    By middle part I mean the bit in my pic above. That is a pic of my line. See how in Chris' pics he doesn't have that part, only the male part on the OEM hard line and the female on the calliper line.
    I think Chris is going to go visit creation Motorsport in the week as they're near him and he'll check what their lines are like.
  18. Westy
    17,443
    1,105
    I'll jump on ms paint in a bit and highlight what I mean by "the middle bit". All the stuff Chris has came off another S3 so I think the seller has missed something.
  19. Westy
    17,443
    1,105
    Just had another look at my pic and I can see that the middle bit is actuall a longer threaded sleeve onto the nut part. My terminology sucks balls!
    Anyway it appears that something is't right and the female part on Chris' lines is too small.
  20. Prawn
    11,719
    3,761
    very odd. there are only 2 parts on yours, and only 2 parts required. Something's up though, as the female part on the new line doesn't look deep enough to me, so perhaps they're some form of dodgy custom line that had an adapter in the middle originally
    :S
  21. rhubarb4
    1,754
    188
    Right these are some I just found that are Vag to Porsche brake lines by HEL they look way different to mine which means they must have been adapted somehow and the adapted bits left on the car.
    Here's a photo what do you think.
  22. Munch
    Munch Member
    256
    23
    Westy, your lines look like the hel ones posted above. I think what prawn is trying to say is that there should only be your line coming out of the brake caliper, that would the screw into your original line. The bit you are classing as the 'middle bit' is an extended thread
  23. <tuffty/>
    21,967
    4,243
    You do realise Bill sells hoses that will work with these?
  24. rhubarb4
    1,754
    188
    PM'd you Paul
  25. Sam_
    Sam_ Down under
    3,039
    485
    HEL lines are awesome build quality if you don't get a set from Bill. They're stainless too, which I'd go for what with the roads being salted back in blighty.
  26. badger5
    9,637
    2,073
    my lines are all stainless HEL fittings..... fyi
  27. aragorn
    18,665
    880
    Bills ones in westys pic look like HEL ones to me anyway.
    edit: Haha bill beat me to it :p
  28. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,306
    375
    this is the end of the hose that bill sells (for LCR Brembo - dont know if they are different to what you need for the porsche)
    and caliper side below
  29. Sam_
    Sam_ Down under
    3,039
    485
    Oh, cool. Well like I say, the HEL lines seem really well made. I've yet to fit mine but the ones I got direct (HEL are Australian) use a banjo fitting on the caliper end and have a different end for the mount on the inner wing:
  30. badger5
    9,637
    2,073
    those bulkhead fittings I have on other hoses I do, BUT, in my experience, vag dont have consistent use of the brackets, and the diameter of the fittings "sometimes" wont fit.
  31. rhubarb4
    1,754
    188
    Great pics Alex nice one there the ones I'm after. Sam the ones you have are the same as the ones I have but only at the caliper end, god knows what kind of adaptor the guy I got them from had to fix to his S3.
    I just popped to Creation Motorsport they have a set of stainless HEL lines for £50 tuffty gave me a rough price on Bills so I'm going to give him a ring and get a definite price when I get chance to nip out. I tried this morning with a 10mm stud no chance looks like it may be a 9mm thread or maybe an imperial thread rather than metric.
    These things are made to try us, the joy of modding cars eh.
    Chris.
  32. Westy
    17,443
    1,105
    I'm glad I wasn't going mad mate!
  33. Sam_
    Sam_ Down under
    3,039
    485
    I hate this kind of stuff, I've attempted to fit my brakes twice already and come up against problems. First the wheels weren't ever going to clear the calipers so I bought bigger adapters. Then the caliper adapters/carriers fouled part of the hub so I have to grind it back but didn't have power. Third time lucky. My brakes are shagged so really need to get them sorted.
    Hopefully these lines sort your issues.
