HELP! Boot Keeps Opening!
Pete20vt Jan 5, 2011
  1. Pete20vt
    Pete20vt Supermoto Junkie
    121
    After unlocking the car the boot opens?! I can hear the lock operating as if i'd used the boot open button by the number plate lights. Even if i get out and shut it the motor goes again and it opens again! This obvioulsy isnt good as the motor keeps persisting in opening the boot any time the car is unlocked including while driving.
  2. Pete20vt
    121
    Will take the boot trim off and check the switches as maybe they are stuck on?
  3. 19scotty81
    19scotty81 Push down and across !!!!!!!!!
    107
    Check for water in the microswitch when you get the trim off !
  4. Pete20vt
    121
    Thanks, will do.
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    yeah, common problem, something to do with the rear wash leaking iirc
  6. Pete20vt
    121
    Connectors dont look too bad at all, there is a tiny bit of corrosion in each connector so have added a little WD40 to see if that helps.
  7. Pete20vt
    121
    WD40 made no difference. Is it the plugs that play up or the actual switches as it looks like i will be replacing them?
  8. willson1983
    willson1983 New Member
    Did you solve this problem? Mine has started doing it today!
  9. Pete20vt
    121
    No all ive done is unplug both connectors to the two switches meaning that i can only open the boot with the key. Partly as i havnt had time to get to Audi and partly because im not sure what i should be replacing, switches or connectors?
  10. willson1983
    Same solution as me. Also I noticed my touch switched have stopped working guessing at the same time.
  11. 1991ash
    1991ash New Member
    I NEED HELP!!!!!!!!!!!!!!!!!!!!........ i have the exact same problem with my audi a3 Facelift model (2000-2003 shape).. the boot keeps poping open, and once its poped open, i can hear it still trying to pop open!! even wen its open! and it does it wen the car is stationary after being started up, and while driving!! What would cause this problem? can i fix it? DIY style?
  12. jc_1989
    jc_1989 Member
    52
    the easiest way to fix would be to replace both the switches and the plugs/pins. that way you get rid of all the corrosion and have fresh connections!
