Help Bluetooth suddenly stopped working in RNSE
zollybosher Sep 7, 2012
  1. zollybosher
    zollybosher Member
    58
    It was fine 48 hrs ago and now no phone can pick up a signal from the RNSE unit. Can someone advise on how to fix this if possible ? Based in Manchester.
  2. hades-
    9,481
    646
    look in RNS-E menu
    theres a reset for the BT
    mine does it now and again.
  3. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    If that doesn't work then removing power from the phone module usually solves it (the phone module isn't in the RNS-E it's a completely separate module).
  4. zollybosher
    zollybosher Member
    58
    Thanks for the input people, where is the phone module located so the power can be disconnected?
  5. PetrolDave
    1,559
    85
    Underneath one of the front seats - I think the drivers seat on RHD. Might be easiest to pop the fuse - could be F8 or F39.
  6. hades-
    9,481
    646
    but if its been retro fitted it will be behind the rns-e.
  7. zollybosher
    zollybosher Member
    58
    It is factory fitted so look under the seat or pop the fusey eh - cheers
  8. zollybosher
    zollybosher Member
    58
    Thank You
  9. NHN
    29,331
    1,716
    As above, but if it also doesnt connect via vcds then possibly a module fault.
