Help - Battery drain (ongoing saga)
twist123
Hi Guys,
Hoping someone can help me with a persistant battery drain, more info....
http://www.audi-sport.net/vb/car-entertainment/139495-radio-causing-battery-drain-00858-a.html
http://www.audi-sport.net/vb/a4-a4-...9492-radio-causing-battery-drain-00858-a.html
Basically, batterys got a drain, no fault codes at present, was getting intermittent at convenience module till I repaired some wires in the door jamb. Hazard stays on solid all the time, all other electrics seem to be working fine, so is the alarm (as far as I can tell). Dash and interior door signals also all okay. Tried 2 new batteries, alternator is also fine, no blown fuses in dash. Once I Vagcom and clear a few modules (no codes but I clear anyway) the hazard goes off and drain goes away until I next drive the car. So im thinking something in the CAN system.
Scanning now produces no codes, however, going into measuring blocks I get 2 different readings from the rear doors (these have winders). Front doors both go to locked and safe when I push the remote button. Really hoping someone can help as have tried pretty much everything and am losing hope.
Thanks in advance
Have you put a clamp amp meter on the + cable from the battery and checked the drain? The drain caused by the alarm and immobliser should be in the region of 300-500ma at most. How quick does the battery go flat?
612
5K
NHN
10K
NHN
