HELP Bad day at the garage fault code list as long as my arm. 2.0t fsi
slim boi Feb 14, 2012
  1. slim boi
    slim boi Member
    35
    Had the managment light up for a while on my a4 2.0t fsi so thought best take it to my mates garage and plug it in. So once i pulled the codes the results where:-
    P2181-performance malfuncation in cooling system
    P0299-boost pressure regulation control range not reached lower limit reached
    P0441-EVAP Emission control sys incorrect flow lower limit reached
    P0507-Idle control system rpm higher then expected upper limit reached
    P0704-Clutch switch f36 implausible signal no signal/no communication
    P2279-leak in air system lower limit reached intermittent
    Anyone else ever had any of these problems and have any advice cheers.
  2. ChrisFurlong
    ChrisFurlong Avantageous
    343
    Pretty sure P0299 is your DV gone. Easy to replace, cost about £50 and about 10 minutes.
    And from the sounds of it, P0441 sounds like your MAF.
    Just google each code and you should find fixes to all the problems. Did you clear the codes and scan again? Some may have been very old.
  3. RMH1A4cab
    RMH1A4cab I'm in Cruise control
    551
    19
    I agree, clear codes and see what returns then tackle each one, you can get alot of old codes from things like the battery going flat.
  4. Paul B7
    Paul B7 Active Member
    622
    34
    I am in total agreement with this and the previous posting. No need to worry yet just have the codes cleared and see if they return.
    Paul B7
  5. chrisa4quat
    chrisa4quat Active Member
    970
    Check for air leaks
  6. slim boi
    slim boi Member
    35
    All codes have come back up 2day so will have to get my hands mucky first job check for air leaks and change dv I think. Cheers all for your advice.
