help b5 brakes
twostrokepower Nov 27, 2007
  1. twostrokepower
    twostrokepower Member
    131
    hello guys
    will AUDI RS4 B5 CALIPERS,DISCS go straight on to my A4 2.8 quattro B5
    many thanks
    simon
  2. Rev-head
    Rev-head Active Member
    2,987
  3. macca
    macca Member
    525
    i don't think they do if i remember correctly. The s4/rs4 hub carriers are different.
  4. twostrokepower
    131
    WOULD I BE ABLE TO CHANGE TO S4/RS4 HUB CARRIERS TO USE RS4 DISCS? BECAUSE MY 2.8 BRAKES ARE NOT UP TO THE JOB OF PULLING UP SUCH A HEAVY CAR , HAVE TRIED CROSS DRILLED DISCSA ND UPRATED PADS BUT FIND THE 280MM DISCS ARE JUST TO SMALL.
    THANKS
  5. docurley
    4,071
    85
    Ok here what you can do Satans Child is selling S4 Hubs with new barrings you will just need to swap out the drive shafts as the S4's will not mate up with the Gear box flanges. then rou will be able to mate S4 or RS4 brakes and disc on that.
    Or do the TT carrier conversion with a set of A8 discs.
  6. twostrokepower
    131
    HAVE TRIED TO CONTACT SATANS CHILD 3-4 TIMES WITH NO REPLY I WANTED AND STILL DO B5 S4 SPEEDO CLOCKS HE HAD FOR SALE .
    THANKS
  7. Markey
    Markey Active Member
    2,175
    I thought the S4/ A4 had same PCD so the disks would fit the same ?
  8. docurley
    4,071
    85
    Disc will mount not sure they would work with stock calipers with TT carriers.
  9. Markey
    2,175
    Ok cool as i have the disks and some differnt calipers on the way just need to get some carriers made up or i was hoping that there were some out there that would fit :)
  10. docurley
    4,071
    85
    You will be the pioneer on this one.
  11. Markey
    2,175
    Dam it and there was me thinking that i could copy someone :(
  12. docurley
    4,071
    85
    Or may be think along the S8 brembo route as a carrier looks to be quite easy for that.
  13. Markey
    2,175
    Not sure i have the movit brakes coming and i really like their quality think there better than Brembo.
    I will see what i can do i may just sell the disks and get different ones with TT carriers.
  14. docurley
    4,071
    85
    Movit are good so stay with them, me on the other hand work to a budget and the budget needs to include servicing and that means pads.
    The B7 RS4 & RS6 Brembo pads cost £300 for a set which is a killer but for my B5 RS4 calipers I picked up a set of pads new for the front and rear for only £70 so this is a strong factor when upgrading although S8 Brembo's seem good with a £100 for a set of front pads.
  15. twostrokepower
    131
    OK IVE BEEN OFFERED 2 POT RS4 CAILPERS AND DISCS FOR £180 SO MAY JUST BUY AND SEE IF I CAN MAKE THEM WORK ON MY 2.8 QUATTRO ? WHAT DO YOU LOT THINK
    THANKS
  16. Markey
    2,175
    2 POT i thought all RS4 brakes B5 shape were 4 pots.
  17. docurley
    4,071
    85
    Not the B5 RS4 they are just bigger version of the S4.
  18. Siena
    Siena Active Member
    2,626
    No. S4 clocks don't plug into pre-facelift cars, plugs and wiring harness are different.
  19. twostrokepower
    131
    thanks for info ,have been told they do , dam!
  20. docurley
    4,071
    85
    Satan's clocks are not face lift but pre-face lift
  21. twostrokepower
    131
    so they will ,,,great
    thanks
  22. satans child
    satans child project...satans child
    141
    hi twostrokepower i am still a member..
    ive been logged in all week but i have no pm from you???
    i still have my clocks .. pm me asap
    dave.. if i dont speak to you before the weekend have a good holiday....
    watch dem lions .....:p have a wicked one bruv...:salute:
  23. twostrokepower
    131
    hello satan
    have just sent 2 pm to you please give me a call 01288 321 033 or pm me your moblie
    thanks
    simon
  24. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    i have some RS4 calipers and brackets for sale if anyone wants them. good nick.
    in the process of getting some adapters made up for B5 A4 hub carrier - B5 S4/RS4 caliper carrier
    just waiting for the spare hub carrier to arrive!!
