Help!!! Audi A4 2.0tdi issue
KalEl May 23, 2013
  1. KalEl
    KalEl New Member
    14
    I have a 2007 Audi A4 Avant 2.0tdi 170, driving hame last night (late) All of sudden glow plugs warning light on dashboard. Car had loss of power had to slow down for roundabout but couldnt pick up any speed so stopped at side of road. Car was still running but no power quickly switched off engine restarted ok but no power. This morning it started as usual but a few seconds in judders & cuts out WTF Any ideas/suggestions? When I was reving it there was smoke coming out the back couldnt see colour due to time. Just had a new DPF filter fitted less than 3 months ago
  2. ukdan
    ukdan Member
    72
    Sounds like an injector failure but you'll need a diagnostic scan to be certain.
  3. KalEl
    KalEl New Member
    14
    Injector failure, is it pricey? I have it booked in next Tuesday
  4. ukdan
    ukdan Member
    72
    Audi has a recall for 170bhp diesel engine injectors so give a main dealer a call with your cars details.
  5. snoopy
    snoopy New Member
    27
    We had the pre-heaters done on our A3 tdi 140. The engine check light came on then, not the glow plug light. Didn't effect the running of the car though so your's could be injectors. A mate had this prob with a Golf tdi and got some injectors from a breakers yard for next to nothing.
  6. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    Considering the level of smoke and lack of power, ive only seen this on cars with faulty airflow meters or boost pipes popped off.
    Where are you based maybe somebody local could check for fault codes with VCDS before sending it into the garage. Have you checked for any abnormalities under the bonnet yet?
  7. KalEl
    KalEl New Member
    14
    Im up the top of Scotland, I foned Audi the previous owner had the injector recall & fixed November 2011 is there any warranty on this part?. I don't know enough about cars 2 look but will get the fault codes & c if a local garage can help. Airflow meters ok is it expensive
  8. Paul B7
    Paul B7 Active Member
    622
    34
    I hade a Mass Airflo Meter (MAF) fitted by local indie at my last service for £60. Its literally a 5-10 minute job to fit one .
  9. KalEl
    KalEl New Member
    14
    Well fingers crossed, I can't justify spendin more stupid £s like the dpf. Will update when I find out on Tues.
    Thanks 4 the advise
  10. KalEl
    KalEl New Member
    14
    So it was the EGR valve needing replaced, badly clogged up. Just think its rather fishy how the dpf filter was replaced less than 3 months ago & this wasn't picked up. It must of been clogged up then due 2 the faulty dpf it cud of been cleaned bk then
    Instead that's about £600-700 down the drain, the amount I've spent in the last few months I have put some serious thought getting rid of the Audi
  11. Paul B7
    622
    34
    A new EGR fitted by an Indy will be around £250, good luck !
  12. Wrath
    Wrath Well-Known Member
    1,196
    42
    I'd have tried to clean the EGR myself.
  13. KalEl
    KalEl New Member
    14
    The flap was seazed open wudnt budge, I just hope that's it 4 now. Had enough spent on the Audi this year
