Help!! Audi A3 1.6 tdi or 2.0 tdi
Mutty2000 Jul 3, 2013
  1. Mutty2000
    Mutty2000 Member
    33
    Hi All,
    I am thinking about purchasing a audi a3 1.6tdi sportback, but have been put off by various threads informing users about the low MPG return. I do a daily 20 mile one way commute at 70-80MPH in free flowing traffic. I am now in two minds about if I should purchase the Audi A3 2.0 tdi sportback rather than the Audi a3 1.6tdi sportback. Any Advice?
  2. sliced
    sliced Drive safe, stay alive.
    1,568
    335
    Go for the 2.0Tdi it's more refined, and has more power which feels a lot better on motorway driving.
    tbh, test drive both and see how they feel
  3. Mutty2000
    Mutty2000 Member
    33
    I currently own a VW Bora 1.9 tdi and have test drove the 1.6tdi on normal road. It didn't feel too sluggish as my main aim is increasing my MPG. Do you believe the 2.0 tdi would give better MPG then the 1.6 tdi as I will doing more 70MPH plus motorway driving?
    mozza1202 likes this.
  4. Patrick_c99
    Patrick_c99 Member
    198
    I've got a 2.0 140 and it has loads of poke and im still getting 42mpg with 4 worn out injectors lol.
    Seems to be the best a3 to go for
  5. SPARTAN91
    SPARTAN91 RED FIVE STANDING BY Regional Rep Team Silver Audi A3 TDi
    484
    167
    43
    Defo the 2.0lt as Sliced said 1.6tdi is a to smaller unit to pull the weight of the A3 and give good mpg
  6. thesmileyone
    thesmileyone Active Member Gold Supporter Audi A3
    474
    46
    My dad has a mk7 golf 1.6 tdi bluemotion, its not bad. Pretty much silent especially at idle, makes a nice induction noise at low revs, much nicer than my 140tdi! £35 a year car tax and he gets 60 odd mpg.
  7. Mutty2000
    Mutty2000 Member
    33
    These sort of replies confuse me more :-s, what type of driving does your dad do is it A road or Motorway?
  8. Mutty2000
    Mutty2000 Member
    33
    Looks like alot are in favour of the 2.0 Tdi 140 bhp plus these are 30 per yr road tax :)
  9. TDI140
    TDI140 Well-Known Member
    1,632
    175
    On motorway sitting at 70mph for over 10minz my average was 49mpg and mine is quite tuned
  10. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    WORN OUT INJECTORS ????
  11. Zak0123
    Zak0123 Active Member
    540
    77
    Both will get good returns on that kind of journey. Makes sense that the 1.6 would give you better MPG, its certainly not sluggish (I have a 3dr) as Mutty2000 said but I would certainly go for the 2.0L if its a sportback as this might be too much for the smaller engine. If theres not much in it, go for the 2.0L! :icon_thumright:
  12. sliced
    1,568
    335
    I get around 58mpg on the motorway in my 2.0 tdi :)
  13. Sidhu88
    Sidhu88 Active Member
    808
    76
    59mpg on a pd170 on a motorway journey. I had a 62 plate 1.6 tdi for a few days as a hire car, and in my opinion u have to work that engine to get going. In the 2.0l ull find everythings alot lot more effortless. Got 2.0, if u go 1.6 im sure u'll regret it and wish u bought the 2.0
  14. Riichard
    Riichard Member
    37
    I have a 2.0 TDI 140 and on my 40 mile commute to work I can get anywhere between 65 and 80 mpg with very careful driving. I've got a couple of pictures to back me up because I realise how silly that sounds!
    Also for economy driving cruise control is your ENEMY.
  15. Zak0123
    540
    77
    80mpg is epic! Maybe the 2.0L can give better returns as you don't have to drive it as hard. How many miles do you get from a tank? Been playing with the idea of cruise control but guessed that it wasn't great for economy! :ermm:
  16. Riichard
    Riichard Member
    37
    This is actually my first week at work so I'm not sure. A quick tot up of calculations means I've done around 335 miles and I still have 2/3rds of a tank left. If I get 900 miles out of it I'll be very happy.
    As for cruise control - it's because usually there are small hills etc on the roads. To get better economy you want slight SLIGHT acceleration downhill so you're not placing much load on the engine at all but still gaining speed, then on the uphill you are decelerating slightly so your economy doesn't go down the pan. With cruise control you are keeping the same speed downhill, which sure helps but then on the uphills it tries to maintain the steady speed ruining the economy. I do about 50-55-60 on the motorway depending on hills etc and that's how I managed to scrape 80MPG!
    For slower situations reading the road ahead really helps. Brakes waste fuel; if you see cars moving slowly ahead and/or junctions put the car in the highest gear possible and coast towards it, only braking when you really need to. It helps massively!
  17. Mutty2000
    Mutty2000 Member
    33
    What does your 140 tdi get and Not many 1.6 tdi drivers :-S, must be a reason for this....
  18. Sidhu88
    808
    76
    2.0 tdi been around since 2004. 1.6 2008-2009 onwards i think. Also, theres a pd140 and a cr140, so there will be differences there too. There is also pd140s with and without dpf's, again there will be differences in performance.
  19. sliced
    1,568
    335
    think the 1.6tdi replaced the 1.9 tdi's
  20. Mutty2000
    Mutty2000 Member
    33
    I did my research and te 1.6 tdi replaced the 1.9 tdie and they have moved over to 2.0 tdi now and have stopped making the 1.9 tdi engines. Something about a common rack rail .... I am disappointed with the 1.6 tdi being this uneconomical.
  21. RobbieWebs
    RobbieWebs Well-Known Member VCDS Map User
    1,031
    249
    Just get a 2.0 tdi 140. U would regret getting a 1.6 after a while I'm sure ;). Using cruise control I can still get 58 - 60 mpg doing 70mph. Sounds like more hassle than its worth trying to get 80 mpg ... The whole point of the car is to enjoy it and have a play around with the throttle not scrimp on using fuel lol :)
    SPARTAN91 likes this.
  22. Zak0123
    540
    77
    Agreed! Good to know what you can achieve though. Might try 50mph for the 30 mile journey tonight and see what I can achieve! Super exciting stuff! NAT.
  23. Minstadave
    Minstadave Member
    560
    19
    Should have got a 2.0T then.
  24. Riichard
    Riichard Member
    37
    Depends on the car and the person I suppose! I bought the 140 for the balance of power and economy. I'd much rather spend 10 mins extra in my day driving slower and getting buzzed to the music I put on than wasting fuel. Then I can spend the extra cash on mods/upgrades and other things in life like alcohol!
    My thoughts exactly.
  25. RobbieWebs
    1,031
    249
    Agree with that but the diesel is a fine compromise of power and economy and 30 quid road tax a year :)
    Everyone to their own bud, I always have the best intentions of driving normally but cant help myself with a quick blast past a few slow moving vehicles ... :p
    Its not really wasting fuel, just a different way of spending it ;) lol
  26. Mutty2000
    Mutty2000 Member
    33
    Thanks for the advice now, I am looking for a 2.0 tdi on a 59 plate :). Anyone selling one eh :p
