Help asap. Fuel filter!
ian52 Jan 17, 2010
  1. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    How do you get it out? Mine decided to **** itself and I need to change it. I take it the filter for quattro is not the same as fwd? In halfords the filters are ones that you put a rubber hose on each end and the end I can see on mine is a banjo bolt. Halfords don't seem to do the one I need. Nightmare!
  2. ian52
    1,199
    Anyone?
  3. aragorn
    18,019
    716
    Motorfactors?
  4. Broken Byzan
    13,237
    465
  5. Broken Byzan
    13,237
    465
    As pointed out by Kev, the pic is generic, if you stick your regnumber in they will ensure you get the correct one
  6. ian52
    1,199
    Cheers. Going to a motor factors on my way home to get one. It went on my way to Newcastle but I think it was not long after I left. 160 miles took 45 quid. I was on my way to pick up new wings when it went.
  7. Broken Byzan
    13,237
    465
    looking at the sate of the corrosion i would say mine has been seeping a bit too
    Till it gave out and started pumping superunleaded on the road.
    As for FSH, mine has never been changed, audi part number with manu date of 2/99
  8. Matt82
    Matt82 Active Member
    2,365
    things like fuel filters rarely seem to be on service schedules, same as gearbox oil etc
    ill have a look at mine because mine goes through petrol fast enough as it is
  9. Matt82
    2,365
  10. ian52
    1,199
    Got a filter now so just need to get the old one off tonight.
  11. Broken Byzan
    13,237
    465
    Tank dropped slightly
    Split in the clamp after i chiseled it to release the filter
    Grubby pain in the Arris
  12. ian52
    1,199
    I was hoping i wouldnt have to move the tank as well.
  13. ian52
    1,199
    Job done. I just cut through the bolt with a hacksaw blade. Im sure the car feels better now. The date on the old filter is 1999 so i bet its the original and had done 185k miles. Where the bottom banjo bolt goes onto it was like cheese and full of holes,probably the salt on the roads was enough to kill it.
