HELP! - Almost There With headlight Washers...
imported_kbininger Jun 13, 2005
  1. I hope my headlight washer cap odyssey is almost over. Got the caps from the dealer for $14 each (hope they made a small profit). They offered to paint them for $40, but I got a can of matching paint and clearcoat and did it myself for $9.00.
    Anyway, I can't seem to get them attached. Is there a way to pull the washers up so that I can clip on the caps? When I try to clip them on now they won't go past the sprayers.
    Thanks!
  2. Markey
    Markey Active Member
    2,175
    You need to grap the washer and pull it out then you will find two little round clips that stick out from either side of the washer and the cap clips onto these.
    Failing being able to pull it out get someone to squirt them and grab them when they pop up!!!!!!! :)
    Make sure you put somthing round the edge where the cap sits as if you put them on the wrong way and need to get them off again you dont want to scratch the bumper.
