Help again please, will these fit? unsure
TomMycroft May 21, 2012
  1. TomMycroft
    TomMycroft Member
    122
    iv been told i can fit wheels with offset 45 and above, but are these too high above?
    theyre the titanium alloys you see on newer style A3'S
    Audi TT RS 19"X9'' Titanium wheels
    offset ET52
    Continental Conti Sport Contact 3
    255/35ZR19
    will these fit my 08 sportback 2.0tfsi?
    thank you :)
    Tom
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    Unlikely lad think but the time you spaced them from the struts they will poke too much
  3. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,751
    353
    9J is harder to fit due to the strut - arch gap being something like 9.5" (so there's not a very wide ET range that'll fit). ET52 is too high, but they can be spacered down to something like ET44 (8mm spacer) and should fit then.
    You'll definitely need to remove arch screws though, and run 225/35s, but they should be fitable (if that's even a word).
  4. TomMycroft
    TomMycroft Member
    122
    thank you guys for advice :)
