Help after new head gasket, loosing water??
evomaster3000 Feb 20, 2009
  1. evomaster3000
    evomaster3000 Member
    449
    I've just done a complete head overhaul and got it all back together, fitted new water pump while i was there and i've refilled the coolant, anyway basicially i filled it up slowly to let all the water get through the system after a full clear out.
    But the issue now is after getting her running it's lost/water level has dropped about 1L of coolant.
    This wasn't a fast drop but the car hasn't been properly on a run as it's off the road till april.
    Is it just the coolant re-filling the water jacket/rad/heater matrix? I can't see any external leaks, at worst i've somehow fecked the headgasket and it's burning water? but is this possible?
    I'm sure i fitted it all correctly but you never know, can't elliminate anything at this point?
    I did save most of the coolant from when i took the car apart, but did loose some, i'd say i saved 5L and so far topped up with 2.5L
    The exhaust is a bit smokey but this hasn't been running for 4 months and just had head etc cleaned out and not been run at temp/under load so no time to clear it all out.
    Anyway I'm going to give it a proper inspection and keep an eye on the level for now hopefully nothing to serious, at worst another strip and re-fit.
  2. t2myd
    t2myd Member
    167
    audis are problems cars , just put new engine in mine ,got it out af a passat ,puting it in wasnt hard ,getting it to run is a nightmare , had to swap pumps to the audi pump as passat pumps are coded , then whilst putting belt back on found that 2 camm buckets were damaged im sick of it ,thatys what happens when mates borrow cars .my a4 is a real nace car ,its a 99 avant full black s4 interior rs4s and billstien suspension,:keule:
  3. evomaster3000
    449
    Hmmm tappets broken? mine was on 170k and they were fine, just one or 2 lost fluid and hence tapped alot!
    Now i've replaced them all it runs sweet as a nut!
    The water issue seems ok now aswell, i read up and the coolant capacity is appor 8 litres so 5 + 1.5 not enough, hence low on fluid.
