Help / advice required from retrofit RNS-E users
brucer Feb 26, 2009
  1. brucer
    brucer Member
    51
    Hi there folks,
    I'm basically looking to find out if anyone has had the experience i'm going through just now. I have a Oct 2007 S3 with only one modification that being the RNS-E unit which was fitted one month after getting the car.
    A while back i put my car in for its first oil service & everything was ok, no problems - service indicator reset, happy days!! So then it came to putting it in for its full first service & everything was going great until the technician told me that he couldnt reset the service indicator!! He asked if they car was chipped & i said no, which it isnt so then he said he would look further into it. Finally they came back saying that a command module was broken so they replaced it only to find that they still cant reset the service indicator. The RNS-E unit was brought up in conversation with the technician & they are now claiming that it could be this that is causing the problem but i cant understand this if the service indicator was reset for the oil service? Also they are now saying that my warranty could be invalid because of me making this modification. My question is has anyone who has retrofitted a RNS-E unit had this problem with the service indicator in the past?
    Any help with this would be much appreciated.
  2. Issac Hunt
    1,162
    Sounds to me like they are clutching at straws because they cannot identify the cause of the problem!
  3. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    これで、ここでは、少数の歴史と語ったが必要だ 無名の英雄 この土が削除されます ある人は、継承はされています 造幣局からの輸入 人々の多くがないのにネウルエウンイ 事実、この老いたहेごみमेरे 彼は帽子にゴミ収集した これは、うわっイレオルスがズボンです そして彼は、フラットに住んで協議会
    彼は'真のनानाである 大きな皿の後に起動チクヒギル 彼はउन्हें得ることができる職業を持って 彼は根が何उन्हेंデイジー電話
  4. NHN
    29,417
    1,740
    You can smell it from here, the normal audi BS
    Did they give you the old module to play with if the warranty was void, I'm sure it would work fine if you plugged it in & tested with vcds, sounds to me like they just wanted warranty work tbh, as they get paid direct by audi uk for any warranty, for them it has to be fully justified.
