They're 19x8.5 et32 with a 66.6 centre bore so you need 66.6 to 57.1 spigot rings
i was going to put some on my S4 with 245/35/19 tyres. They would have been fine on the rear but trouble was at the front it worked out as the equivalent of running oem S4/A4 wheels with an 18mm spacer which definitely would cause rubbing issues without messing with you arches
