Help A4 B6 AWX Alternator Tensioner Replacement
samsam Jan 21, 2013
  1. samsam
    samsam Member
    96
    Hi,
    could someone shed some light on this problem......
    i have a whining noise from the tensioner roller what I am wanting to know is can I just buy the v roller it's self or do I have to buy the whole damper / tensioner and can this be fitted without removing the bumper / front of the car .....???? Looks a really small area to work with ....
    Please can someone help me with this
    thanks
    sam
  2. demus
    demus Fire in the hole..
    355
    19
    The front of the car will pull forward into a service position to give you more room.
    I haven't yet had to touch the tensioner on mine (yet..) so can't really comment, but I have in the past managed to replace just the bearing inside tensioners, looks like its made of plastic so not sure if the bearing would press out or not.
    If its done a load of miles then it wouldn't hurt to change the complete unit with dampers..
  3. chrisa4quat
    chrisa4quat Active Member
    970
    Iirc it's complete
  4. samsam
    samsam Member
    96
    It's done 125k.... Is it just a straight bolt on no adjusting ??
    Iirc?????
    ta
  5. StuG808
    StuG808 1.9tdi130 Avant FailWheelDrive
    257
    9
    Once you get to the tensioner roller you are only a few steps from a full cambelt change, so best to do the whole job.
  6. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    yes it just bolts straight on
    A haynes manual says to remove the viscous fan but you don't have to
    not sure if you have to put it in service position as the only time I have removed it was when I did my cam belt so was in service position anyway
  7. Wahlstrom
    Wahlstrom Active Member
    417
    148
    43
    Did mine without removing the front.. Took me 20 mins.. But mine is the AVF, so its the other tensioner..
    But I dont Think You are forced to remove the front.. I was told I was, but still did it without.. So..
  8. Wahlstrom
    417
    148
    43
    Could also be the clutch in the alternatorwheel..
  9. samsam
    samsam Member
    96
    It's a brand new alternator well about 8 months old
  10. Wahlstrom
    417
    148
    43
    Ok.. But see if You Can get it off without removing the front.. The tensioner on mine, is a thick one, and still I managed to get it in...
  11. chrisa4quat
    970
    Iirc if I recall/remember correctly
  12. chrisa4quat
    970
    Can get them from GSF and ECP just make sure premium quality
  13. StuG808
    257
    9
    I stand corrected. I wonder if that's possible with the friction damped one that I have as it needs some fussy calibrating.
