Help! A4 2.0Tdi S line...
vavavag Jun 25, 2013
  1. vavavag
    vavavag Member
    51
    Just bought a late 2005 b7 a4 2.0tdi S line 140.
    Car drives very well, accelerates pretty good to.
    HOWEVER...
    1. When put into high gear and in low revs the car judders violently until about 2k revs and then just accelerates normally. When the car is in 6th gear at around 1200-1300 revs upon acceleration it shakes quite bad. This then stops at 2k revs and the car drives normally.
    2. At idle the car also shakes a little.
    I have had one of these before with an oil pump issue so know what thats like - my last one would shake and judder hard on acceleration no matter the position of rev counter. This car however is smooth high in the revs and will easily go over 80mph!
    What do you guys think it is? Quite worried.
    Any help much appreciated
    Thanks in Advance!
  2. claudefrog
    claudefrog Member
    372
    Flywheel judder?
  3. brownie 25
    brownie 25 Member
    383
    9
    does it make any difference when you press the clutch at idle
  4. vavavag
    vavavag Member
    51
    No difference when pressing clutch. No rattle or play from flywheel when cutting car out. Judder at low revs when accelerating. Friend thinks it may be injector harness?
  5. Conmase
    Conmase New Member
    22
    I have the same problem and I have been told its injectors
  6. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Dont think the car will like being put into 6th at 1200 rpm,no wonder it judders.
  7. vavavag
    vavavag Member
    51
    I had the car put on diagnostic and comes up as misfire in cylinder 4. p0304 or something along those lines.
    Could this mean injector? or injector harness? Put into high gear at even 14-1500 revs the car shakes hard!
  8. vavavag
    vavavag Member
    51
    bump
