HELP a3 quattro just died!
cawood Mar 23, 2007
  1. cawood
    cawood Member
    108
    erm help please
    the birds Audi A3 quattro has just died!!
    there is no life in it what so ever, nothing works, nothing lights up just dead!
    it has been working fine up until now and this has just happened
    need to get it running before we finish work so we can get home n get out on the ****
    guessing its something to do with the bty, gonna get some jump leads n try that & also try cleaning all the contacts. what else?
    heres some pics of the bty, whats that terminal block on top of the bty?
  2. HmanS3
    HmanS3 Member
    154
    is there any juice in the Battery? Have you tryed some jump leads on it ?
  3. HmanS3
    HmanS3 Member
    154
    check the Main earth strap is still attached
    With a complete loss like this its usually some thing really simple
    Try putting jump starting from another car if you have no luck there using one of the jumper leads connect from the Battery - to an exposed area of metal on the Engine block then try it !
    pretty sure it will be the Earth or the Battery is fooBar!
  4. cawood
    cawood Member
    108
    thanks for your help matey!
    wheres the earth strap? lol
    gonna go get some jump leads now n try soon, soon as i can get out of work!
    when trying to jump using the car bodywork, should i use neg to car body n pos to pos on the bty?
    can i use a multimeter on the bty to check for life?
    soz bit simple when it comes to this ha ha
  5. SamDude
    SamDude Active Member
    2,102
    If you turn the ignition, do the electrics turn on?
    Clock/radio/lights?
    If not, then its a safe bet the battery is having a long weekend.
  6. HmanS3
    HmanS3 Member
    154
    i would just go for straight battery to battery to start with mate then if that doesn't work move the negative/Earth Jump lead from your battery to the Engine block and try again
  7. HmanS3
    HmanS3 Member
    154
  8. cawood
    cawood Member
    108
    thanks for help lads
    just jumped it, worked fine! see how it runs over the weekend
  9. IN-A3
    IN-A3 Member
    457
    try looking in view hole for battery condition.
    Undo vent caps and check water level.
