Help! A3 Quattro, cant select gears, wont start/turn over.
PJM_01 Nov 10, 2011
  1. PJM_01
    PJM_01 New Member
    13
    My wife's A3 Quattro (yr2000 1.8T petrol) broke down on her this morning, basically couldnt select 3rd gear initially then stalled and wouldnt restart - I've had a look at it (In the dark) it appears that 1st, 3rd, 5th and reverse arent engaging - the linkage is operating but obviously incorrectly. The gear lever feels spongy too which it didnt previously.
    All dash lights come on but nothing happens when you turn the key, no turning over, no starter engaging or even clicking. The EPC light stays on when the ignitions on - is this normal?
    Any helpful suggestions would be gratefully received! The cars never let us down before.
    Cheers!
    Phil.
  2. <tuffty/>
    20,987
    3,760
    Sounds like the selector fork has gone... fairly common problem which sadly means it a replacement gearbox or yours rebuilt at least...
    Sorry fella
  3. PJM_01
    PJM_01 New Member
    13
    Thanks for the quick reply, I thought it could be fairly major.
    Would the selector fork prevent the car starting even with the clutch down? Whats the association with the "EPC" light? (If any, forgive my ignorance!?!)
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I would think the car should still start... on an auto no...but a manual?? what would be stopping it?...Bizzare?:think:
    All i can think of is the engine is siezed, or a main earth strap has snapped, you could check the fuses on top of the battery, i think one is a main isolator...
  5. <tuffty/>
    20,987
    3,760
    Don't know tbh... need to get the car scanned to find out whats doing that... could be the crank sensor or something but a fault scan will tell you..
  6. s3dave
    10,110
    736
    Reading it again, check an engine mounting as not snapped breaking wires plus making the linkages inoparative, dont worry about the ecp light at this stage...
  7. colicabcadam
    colicabcadam Guest
    what makes you think it's actually out of gear? somethings broken in the gear box which i believe has locked it in gear
    does it turn over if you press the clutch down? can you push the car forward or backwards?
  8. egesford
    egesford Member
    346
    i had a similar thing happen. the dual mass flywheel was bent, which smashed the clutch to peices, which damaged the gearbox jamming it all together. wasnt cheap
  9. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,260
    357
    Thats a bit weird if it is selector forks. There are 3 selector forks for gears 1&2, 3&4, 5&6 so if a fork was broken it would take 2 adjacent gears out? Maybe its just the forward throw gears? R, 1, 3 & 5 are all on the forward throw of the gear stick. Is it stuck in gear? Can you push it with the handbrake dis-engaged?
    I had a selector fork go on me whilst i was in gear, so i was stuck in that gear (5th or 6th). When it went the gear stick felt really spongy too like you say. Could be. I could start the car though (clutch down).
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/114131-s3-gearbox-problem-breakdown.html
  10. PJM_01
    PJM_01 New Member
    13
    Thanks for all the input so far, I havent had chance to look at it yet (just about to look now). It wont start with the clutch up or down, I assume It did roll with the clutch down as it was winched up onto a recovery truck and rolled down the drive when it got home.
    I'll go and have a play now and update if I find anything of interest. A mate has a fancy snap-on diagnostic reader he's lending me during the week so I can check any fault codes etc then.
    Thanks again people ;-)
  11. PJM_01
    PJM_01 New Member
    13
    Right, this is what I've found so far -
    The car does roll freely with the clutch pedal pressed.
    It is stuck in gear (3rd I think)
    The engine appears fine, the crank etc rotate when the the car is rocked back and forth with the clutch up (and stuck in gear)
    It still doesnt want to start or even turn over, even with the clutch depressed.
    Fairly sure the gearbox is fooked. Is this a weak point in the quattros? Anyone got an idea of cost for a rebuild or replacement?
    Phil.
